Speedometer change when changing gears?
Old Mar 17, 2006 | 08:09 PM
Tom.Lapham's Avatar
Tom.Lapham
I've got a 1991 f150 4.9L 5spd with 2.73 gears. Am swapping to a Limited Slip TrakLok differential and 3.55 gears. The speedometer cable hooks into the tranny on this one - what's it going to do to my speedometer reading?
Old Mar 17, 2006 | 08:34 PM
kc7smo's Avatar
kc7smo
It will make your speedometer read faster than your actual speed if you do not change your tires size.
if you drive between two mile markers at a constant speed, count how many seconds it takes to go that one mile. Divide the seconds it takes you by 3600, then do 1/(Whatever your seconds divided by 3600 is) and this will give you your speed, based off the old high school D=RT (Distance = rate x time). The 3600 is there because you need to convert the seconds into hours, so you get MPH as a result. This will tell you how much your speedo is off.
Ex: 45 seconds to go one mile: 45/3600 = .0125
1/.0125 = 80MPH. Quick check and this is right, since if you took 60 seconds, you would be going 60MPH. And 30 seconds would be 120MPH.
Or, just take it to a speedo shop and have it recalibrated for aprox $100.00
