Sponsored by: Kumho
speedometer to read correct
Old Jan 23, 2002 | 10:42 AM
chulsey12's Avatar
chulsey12
how can i make my speedo read correctly with 35' tires and 3.55 gears
Old Jan 23, 2002 | 10:57 AM
AZ4x4f150's Avatar
AZ4x4f150
you need to change the gear at the end of the speedo cable that goes into the transmission a dealer or 4x4 shop should have the different size gears for your setup in stock. or follow a car have the driver of the car go up to freeway speed and note where your speedo reads so you know where freeway speed is. changing the speedo gear is a fairly simple job
Old Jan 23, 2002 | 11:33 AM
rabidranger's Avatar
rabidranger
Unless you have VSS. Look for a wire coming out of the rear diff. If it does you have VSS (vehicle speed sensor). It uses a ring in the diff to measure speed. You will need to recalibrate the computer at the dealership, or I belive superlift makes a module that you can use to do this.
Old Jan 23, 2002 | 12:18 PM
MustangGT221's Avatar
MustangGT221
Yes, there is an ABS sensor coming out of the top of the rear differential, theres a plug at the top. If you that, you have an electric speedometer and you can calibrate it yourself. Do a search for "speedo calibration" and you will dig up all the info you need, including directions, on how to recalibrate your speedo by urself. But, thats only if its electric. If it's a cable, you will need to do what he said above. All the dealer does is do a simple thing that you can do yourself, while charging you 50 or so dollars to do it. Its easy and you can do it yourself instead of letting the dealership do it.
Old Jan 23, 2002 | 07:07 PM
chulsey12's Avatar
chulsey12
but how do i do it
Old Jan 23, 2002 | 07:13 PM
flyboy2610's Avatar
flyboy2610
Do what? Change the gears or recalibrate an electric speedo?
Old Jan 24, 2002 | 12:21 PM
MustangGT221
If ur going to recalibrate your speedo, do what i said, do a search under "speedo Calibration" on this website and you will find the instructions on how to do it.
Old Jan 24, 2002 | 03:10 PM
MustangGT221
Slankky
Nov 6, 2011 05:49 PM
crazymut
Sep 5, 2008 11:59 AM
Phredawgy
15
May 1, 2007 06:35 AM
dunebuggys
Jul 8, 2000 10:09 PM
