overheating problem...Clutch fan???
Old Jun 10, 2017 | 01:34 PM
hturner12's Avatar
hturner12
I think it is 192 maybe 195. Make sure and get Motorcraft. That and glowplugs
Old Jun 10, 2017 | 11:28 PM
3000gtman's Avatar
3000gtman
Originally Posted by Bonanza35
You don't have oil in your coolant do you? When mine did this, new, it was an oil cooler failure. But you could see the oil in the coolant. Just a thought.
​​​​​​​nope
Old Jun 15, 2017 | 09:21 AM
genscripter's Avatar
genscripter
Originally Posted by 3000gtman
Again while running the fan is kinda hard to stop from spinning. But with some force I can stop it from spinning.
I should have clarified in my original post....
With the engine OFF, use your hand to spin the fan blades. If it spins freely, then the clutch is bad. There should be a viscous-kind-of resistance to the spinning of fan clutch with the engine off.
Do not attempt to stop a fan clutch with the engine idling or running.
Old Jun 18, 2017 | 06:58 AM
jayro88's Avatar
jayro88
Genscripter is right about the way the fan should feel when spun by hand.
The coolant should be being pumped regardless of pressure. If its not moving then it could be your water pump. I would recommend changing the thermostat since its cheap. If that doesn't fix it look at the water pump. I replaced my fan clutch when I did my water pump simply because you have to remove it to take out the water pump.
From reading it appears that the fan clutch does not lock until the 230ish range with the OverTemp light kicking on at 240*. Some have had luck testing their fan by blocking off the radiator and running the engine at high RPMs while parked. I tried this, but was never able to get the temps high enough. There is a procedure you can do to adjust the temp spring in the fan clutch to kick it in at a lower temp if you want. Also, make sure the fan clutch spring is clean. If it is covered in crud it will be insulated from the heat and delay it kicking in.
Old Jun 23, 2017 | 02:27 AM
hairyboxnoogle's Avatar
hairyboxnoogle
Going to have to side with the t-stat crowd, or bad water pump. If the fan is doing ANYTHING at idle, it shouldnt get warm, unless you dont have a shroud. I also ran for a long time without a fan when it failed. Only time it would get warm was extended idling and pulling long hills, and thats with a very clogged radiator ( even with a fan it gets hot on the hills, just not as much lol)
Old Jun 23, 2017 | 04:43 PM
Racerjay's Avatar
Racerjay
fan clutch is bad, thermo is suspect. Take the thermo out and test it in boiling water. You should be able to hear the viscous clutch energize and de energize your fan.
1999-F150
1997 - 2003 F150
Jul 1, 2018 10:00 AM
Rick_Fury
Mar 16, 2012 07:20 PM
dogg16
Bronco II
Jul 12, 2007 01:33 PM
mhilow
1983 - 2012 Ranger & B-Series
Dec 20, 2006 08:35 AM
Hamberger
Sep 14, 2006 07:30 PM
