I did a google search using those part numbers and some of them came up as a 1974 cap. Just so I am clear on what I have, is the distributor that I showed in the pictures an original 1967 that came with points/condenser and was converted to different internals, or is that a later model electronic distributor that was taken from another engine? If it is an original converted to electronic, does the conversion also change the cap to a different part number or does the cap and rotor stay the same.
Thanks
Thanks
No such thing as a 1974 distributor cap.
The cap (it was black originally) is the same 1957/74 V8's (except HiPo's): B7A-12106-A has female ends.
1957/74 HiPo & 1975/76 cap (it was blue originally and called a H/D, replaced the 1957/74 B7AZ-12106-A brown HiPo cap): D5AZ-12106-A has female ends.
1977: Ford introduced new I-4/I-6/V6/V8 caps with male ends, also required was an adapter that was located below the cap that the cap clipped to.
You can use either B7A-12106-A or D5AZ-12106-A dizzy caps on your 1967 F350 352, because the cap it has now...has female ends.
So long as the distributor innards and vacuum advance aren't all clapped out it will be about as good as it gets with a pertronix module installed. Keep a set of points and condenser in the glovebox and if the module were to die out on the road or wherever, can get going again in a few minutes. Backwards compatibility.
Ok I'll look for those parts online. No worries about any confusion with part numbers. These trucks are not easy to follow. My head is spinning with this stuff everyday, but I love it.
You know, the FORD P&A System (MOTORCRAFT either) is not all that hard to fathom once you understand it. You would be surprised (I was) with the number of counter-persons who do not know/understand the system.
CRS Update-
Let me allow to add to the confusion here. The wire set PN you have (and it is the correct Service Part Number) is a universal set. It is designed to fit more than one engine series other than the FE, those being the 335 and 385 Series. That being said, if you want the original look (cleaner), look for a quality RE-PRO set C5AZ 12259-F wires (AUTOLITE - MOTORCRAFT).
These were the hot lick back in the old days and even had spark plug heat shields on them.
Reason: ADDING TO THE CONFUSION
I am now retiring to my safe spot to hopefully survive the expected incoming...
Not at all. Everybody makes mistakes. Being human. We here in the Bumpside Kingdom are no where's as "stiff" as posters on other forums I've read. Don't let it make you gun shy to help in the future.
APPRECIATE IT!
Fact of the matter is I am getting long in tooth.
I saw the photo of the blue cap and I immediately thought of D5AZ-A forgetting entirely of it's being superseded by D7TZ.
I'm older than you are, but you're older than JEFFFAFA and probably many other members of this forum.
1973/79 Ford Passenger Car Parts Catalog, final printing 11/88: It doesn't say that D7TZ-12106-A replaced D5AZ-12106-A
What is does say: D5AZ-12106-A Dizzy Cap (female ends): 1975/76 V8's.
E2ZZ-12106-A Dizzy Cap (male ends) & E2ZZ-12A217-A Dizzy Cap Adapter: 1977/79 V8's.
I don't see how you can use a 1977 and later V8 male end dizzy cap that uses an adapter that the dizzy clips to...in place of a 1976 and earlier female end V8 dizzy cap.
Edit: I just spoke with JEFFFAFA, D7TZ-12106-A did replace D5AZ-12106-A (according to his 1989 O-S-I catalog).
But...even though this dizzy cap has a 1977 part number, it has female ends. Typical FoMoCo confusion.
Yepper. Just to get that 100% sure factor in there, I called next door to out Motorcraft warehouse. They are called Parts Mart but are also owned by the owners of Sanderson Ford. I had a parts puller go eyeball the D7TZ12106A (DH370). It does indeed have female terminals.
Typical FoMoCo confusion all right. I can't tell you how many gazillion times I've told a customer that sometimes being a Ford Parts Man you have to do some Sherlock Holmes work to look up or figure out the correct number.
I am wondering (as I often do as I watch a striked match) why the service upgrade to the D7TZ from the D5AZ. Was it for a design purpose or was it just done to have the cap match the new corporate engine trim color (gray) which I hated BTW.
And while you have your OSI out, can you trace the B7AZ 12106-A -NR-NS-RB- in it's relation to D5AZ? It may require an earlier issue.
I believe it's main usage was on transistor ignition systems on the HD truck engines of the period mainly but TI was carried until about the 1967/68 car model tuns. It was also used on HP TI systems.
The questionable years here are 75/77. So I 1st went to my Dentside 73/79 F100/500 slide. Here I have the up to 1976 360/390 and 1977/ 351M/400 applications. As you know, Ford never changed the Dizzy diameter of the cap's mounting surface between the V8's 1957 to the end of Dizzys. It shows the following as stated on the Oct 1988 final issue as stated. Not tracking any later part number changes yet.
73/74 F100/350 360/390 taking B7A12106A (not B7AZ) (DH6)
75/76 F100/350 360/390 taking D5AZ12106A (DH354)
Next I went to 351M
75/76 B-F500 (what?!?!) 351M with CAL. em. D5AZ12106A. Points Dizzy.
77 B-F500 351M with and w/o CAL em. taking D7TZ12106A and a matching (prolly gray also) D7TZ12200A rotor. Still a points Dizzy.
77/79 F100/350 351M taking the 2 piece cap with male terminals.
My Jan 1989 O.S.I. slide shows both:
B7AZ12106A r/b D5AZ12106A.
D5AZ12106A r/b D7TZ12106A.
Currently my Ford computer on DOW shows:
B7A12106A r/b D7TZ12106A.
My 49/59 Car slide shows B7A12106A fitting 57/59 Ford and T-Bird all V8's. No mention of B7AZ12106A.
My 60/64 Car slide shows B7A12106A fitting V8's w/o transistorized ignition. B7AZ12106A fitting V8's with it.
