Blowing fuse in reverse
Old Jun 8, 2017 | 06:17 PM
Equinechel's Avatar
Equinechel
Hi, I am new and have had my baby (2002 excursion diesel) forever. We just got a new camper. It seems that when put in reverse we keep blowing the #38. Any ideas would be amazing. Thank you. Chel
Old Jun 8, 2017 | 06:57 PM
senix's Avatar
senix
what happens if you don't have the camper hooked up and put it in reverse?
If the fuse stays operational then I'd suspect it is with the camper.
I take it the camper is used and you just bought it?
Sounds like a wiring problem with the camper so start at the 7 pin connection on the trailer. Gonna need to verify the wiring/check for shorts.
Old Jun 8, 2017 | 07:02 PM
Equinechel's Avatar
Equinechel
Fuse
It's a brand new camper. The only change get was we added the brake box. I thought it might be that but the man says no. Hahaha
Old Jun 8, 2017 | 07:26 PM
senix's Avatar
senix
What Brake controller? Can you test it on another trailer?
Old Jun 8, 2017 | 07:45 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
Is there a wire on the truck's connector in the center position? Is there any corresponding wire in the RV connector? The center pin is supposed to the reverse position. See this diagram: https://www.ford-trucks.com/forums/5...g-diagram.html
Old Jun 9, 2017 | 03:02 PM
RV_Tech's Avatar
RV_Tech
ten to one you will find the center wired to ground.
Steve
Old Jun 13, 2017 | 10:05 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
Sure sounds like it, Steve.
ford0173
May 1, 2024 03:27 PM
TxFire76
2015 - 2020 F150
Oct 31, 2016 08:28 AM
js32ryder
Jan 17, 2014 01:06 AM
wyldbillracer
All Things Towing
Nov 19, 2004 07:24 PM
MHowell
1978 - 1996 Big Bronco
Dec 27, 2002 06:41 PM
