I have been having an issue with my 04 navigator. When you turn left or right the brakes start to bind, only on the right side and only the outside pad is grinding the rotor. I suspect something is bent. I have attached the specs from the alignment shop and hope that someone can help me here with alignment experience. Does this alignment data show anything wrong?
Other than the wheel bearing/hub there is nothing in the suspension system that could affect the brake. From the printout it looks to me like the upper or lower ball joint (or both) for the front right wheel is worn.
