Alignment: Educate Me
Old Jul 24, 2015 | 08:01 AM
exbxtoy's Avatar
exbxtoy
What do I need to know about getting an alignment done on my 2003 X? I don't want to be sold a bill of goods I don't need. With as bad as the Michigan roads are, does the Firestone lifetime alignment for $200 make sense? The dealer I called wants $69.95.
Also, it sounds like my unit hub bearings are going out in the front. I have a howling noise that is getting progressively worse. Do the bearings affect the alignment?
Old Jul 24, 2015 | 08:50 AM
psycoreefer's Avatar
psycoreefer
Can't speak to prices but bearings will definitely effect alignment, if they are bad you should change them first, as well as ball joints if you need those.
Basically the Ball joints hold the assembly that the bearings ride in, then the bearings hold the wheel to that assembly. Because an alignment is usually measured off the outside of the Rim, anything that effects the position of the rim will have an impact on alignment.
Old Jul 24, 2015 | 11:47 AM
Misky6.0's Avatar
Misky6.0
IF you have 2wd, the only additional complexity to an alignment is the caster/camber adjustment requires replacement of the non-adjustable stock part that holds the ball joint.
With the Excursion (or crew-cab 8' pickup) make sure your alignment shop has the "large" alignment machine - many in my area can't do an alignment on the excursion because it's too long for their "car-sized" machine..
https://www.ford-trucks.com/forums/9...mber-kits.html
Old Jul 24, 2015 | 02:04 PM
exbxtoy's Avatar
exbxtoy
Mines a 4wd, thanks for the info.
Old Jul 25, 2015 | 10:09 AM
Misky6.0's Avatar
Misky6.0
You should create a signature (the banner across the bottom of a post) that details you Ex's vitals - so folks know your engine/drivetrain and any lift/upgrades that can be helpful in the future.. (User CP across the top, then Edit Signature).
Old Jul 25, 2015 | 12:22 PM
The2003Excursion's Avatar
The2003Excursion
I have two vehicles with over 300,000 miles and their first alignments were done at Firestone. LifeTime alignment for those were a good deal for me. I think I paid $90 at the time back in the mid-nineties. If you plan on keeping the Excursion for a few more years, do it. When you replace parts, freebie........
run6.0run
Jun 15, 2012 05:56 PM
keisha9
2004 - 2008 F150
Mar 5, 2011 10:06 PM
Spaggs
Dec 14, 2009 10:00 AM
PSDLOVER
Jun 28, 2009 10:23 AM
