Gatorbacks. No drill style. They use all factory mounting points and no additional holes in the aluminum. Lifetime warranty, toughest option for SRW or DRW. Your dealer should be able to order them as the have Ford part numbers now.
Have you seen our new ROCKSTAR™ Splash Guard Mud Flaps? These mud flaps are easy to install and can be mounted flush or offset for your desired coverage. The decorative trim plates at base of the mud flaps add both stability and style.
I had my Gatorbacks put on today. I arrived at the service center at 8am and they were done just after 3pm. First one they had done. I am happy with them and glad I had prearranged the installation. And it is good to be home at last. (New for the F450)
Here are two pictures showing the no-drill brackets installed and my favorite flap plate design...They really look and perform like a Super Duty truck mud flap..
ForeverFixing did you get the no-drill flaps for the front tires of your F450 as well?
Yes, what would have been no drill turned out to be drill I guess. The Ford dealer bought them retail because they were not available through Ford or they just could not find them.
The installer did not have anything good to say about the instructions. But they are on and I am happy. They look great.
Did he get the F450 specific front flaps? Those are designed for the front wheel wells of the F450 and use existing factory holes. There should have been no drilling into your truck required at all! These were made so that was not needed.
I'm liking my Duraflaps. Got them in extra long, and 14" wide... they do a great job of keeping the truck clean. And the stainless weights look good (went with a decorative one on the rears)
