Started my upgraded sound system
Setup:
Audiofrog GS690 6x9 front drivers
Audiofrog GS610 Tweets for in the pillars
Rockford Fosgate 3.Sixty.3 DSP
Rockord Fosgate P1000X5 5-channel Amp
Rockford Fosgate T1S2-10 10" shallow sub (this thing is amazing and from a blind sound test you wouldnt be able to tell the difference between this sub vs a dvc sub in a much larger box).
Lastly i put soundskin dampener on the front doors and also along the rear firewall where I mounted the sub box, amp and dsp since I had to remove the carpet to make room for the audio equipment.
Pics of the setup!
Rockford 5 channel Amp and DSP behind passenger rear seat
Rockford Punch Power 10" Shallow Sub behind driver side rear seat
Pic of the entire setup (i like this because it allows me to retain all my storage under the rear seat)
Here is the soundskin dampener. I used to use dynamatt but this stuff is much better now that I've used both. It really tightens everything up.
I also installed the Compustar MAXIT remote start/alarm setup. Granted the truck came with factory remote start but I opted to go aftermarket for increased range (3 mile range with the T11 remote) and it also has an integrated turbo timer (when needed after a long drive or tough tow) plus the ignition kill switch and tilte sensor is an added bonus for security.
I'm extremely happy with the way this sounds. I kept the factory rear speakers installed and just moved the fade a few steps forward and also kept the center channel installed since it has some usage for navigation and other prompts that come out of it.
If you've never heard of Audiofrog check them out. They are a newer company and make some very high end quality components that will compete with the JL's, Hertz and Focals of the world. Audiofrog » designed in California for audiophiles everywhere
Enjoy your new stereo!
