Fuel Gauge Voltage????
Old Sep 4, 2003 | 11:03 AM
LesPaul's Avatar
LesPaul
What should the voltage be coming form to the fuel guage. I'm trying to determine if the gauge is bad.
Thanks.
Old Sep 4, 2003 | 11:48 AM
Mil1ion's Avatar
Mil1ion
The fuel sending unit receive a pulsing 5 volts.
Do this,
Remove the wire from the temperature sending unit and check the wire with a test light. If the light illuminates, the ICVR works.
To check the gauge for a the fuel , with the key off,hook a jumper wire to the wires and turn the key for a short time, if the Gauge pegs to the right, the gauge works.
I'm sure the problem is with the S/U, not the gauge.
Old Sep 4, 2003 | 01:11 PM
Franklin2's Avatar
Franklin2
Take the wire off the gas tank that comes from the sending unit. With the key on, ground the sending unit wire. The guage will swing all the way one direction. Then take the wire off ground and let it hang in the air. The guage should swing all the way the other direction. All the sending unit is doing is varying the ground of the guage with a resistor wire inside the sending unit. You won't get any meaningful voltage readings from the sending unit wire.
RadioControlGuy85
Sep 3, 2016 05:59 AM
okiebronco
May 17, 2016 10:40 AM
STEVE1103
Electrical Systems/Wiring
Jun 18, 2014 02:32 PM
Luch
Apr 7, 2013 09:24 PM
inliner
May 15, 2003 04:39 AM
