92 f150 gauge issues
Old May 17, 2016 | 08:35 AM
okiebronco's Avatar
okiebronco
my 92 f150 has dual tanks. i THINK i remember seeing my oil gauge work and volt gauge work ( 2 top gauges) but the 2 bottom gauges ( temp and fuel) dont work. i have noticed with key off, the fuel gauge will sit at 1/4 for some reason but when i turn key on it goes to empty. is there a voltage regulator that controls the bottom gauges on this year truck? or am i barking up the wrong tree
Old May 17, 2016 | 09:52 AM
subford's Avatar
subford
No gauge voltage regulator.
The fuel gauge can set any where with the key off.
Old May 17, 2016 | 10:30 AM
okiebronco's Avatar
okiebronco
How likely is it i have a faulty cluster? i should be able to unplug the cluster and test for resistances at the plug right?
Old May 17, 2016 | 10:40 AM
subford's Avatar
subford
The best way is to unplug the one wire push on temp sensor on the engine, turn on the key and see what the temp needle points to. Then ground the one wire and the needle should swing the full scale the other way.
1980 Ford F-250
30
Oct 8, 2024 04:49 PM
three on the tree
Jan 15, 2019 04:08 PM
Ron1967
Jul 23, 2017 01:14 PM
Ktm350
Feb 8, 2015 08:50 PM
IHdieselfan
Jan 8, 2006 08:00 PM
