voltage gauge
Old Sep 1, 2016 | 02:26 PM
RadioControlGuy85's Avatar
RadioControlGuy85
voltage gauge
what controls the voltage guage? is it the voltage regulator or somthing else?
Old Sep 1, 2016 | 05:07 PM
Franklin2's Avatar
Franklin2
Our trucks never came with a voltage gauge. They did have a ammeter. Is that what you mean?
Old Sep 2, 2016 | 03:00 AM
RadioControlGuy85
i guess, whatever the gauge is thats got d and c on.
i call it a voltage gauge
Old Sep 2, 2016 | 07:36 AM
Franklin2's Avatar
Franklin2
Yes, that's the original ammeter. If you follow the large output wire of the alternator from the alternator to the junction in the wiring harness, you will run across a piece in the wire with two smaller wires on either side. This piece is a shunt. On either side of the shunt are the smaller wires and these travel in to the factory ammeter. The factory ammeter "samples" the voltage drop across this shunt and moves the needle as current passes through the shunt.
I will warn you they don't work that well.
Old Sep 2, 2016 | 08:49 AM
RadioControlGuy85
ok thanks. for the info
Old Sep 2, 2016 | 11:02 PM
4GOTNF250's Avatar
4GOTNF250
Just buy a real voltage gauge from anywhere and install it somewhere and you will be about 40 years ahead of that worthless ammeter, if your into working factory gauges and pure stock look there is a guy converting these to be real voltage gauges (dont remember the business name)
Old Sep 3, 2016 | 05:59 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Rocketman Innovations
Rocketman's Classic Cougar Innovations
Gary Lewis and Jim'sRebel both have threads highlighting this product.
jc302x
13
Jan 20, 2019 05:13 PM
blue70f100
Jun 25, 2010 07:31 PM
littlebig(truck)man
Electrical Systems/Wiring
Oct 6, 2004 11:23 AM
Kikwear
1978 - 1996 Big Bronco
Jan 29, 2004 12:15 PM
cozmo
Sep 27, 2002 10:52 AM
