I am 600 miles from home and noticed that my display says my DEF is below half full. Would I be able to make it home before I have to fill it up or should I just find an AutoZone and do it. I'm not pulling anything so I'm not using extra. I truck came with a 5 year maintenance plan which includes filling up the DEF tank so I was hoping to get to the dealer before having to fill it. Will it go into limp mode if it runs out? This is my first truck with DEF and I've only had it for a few weeks so this is new territory for me. What do you guys think?
I wouldn't worry too much about it. I think it will give you another warning before you get close to limp mode. Does your trip home not take you near any major stores like auto zone, wal mart etc where you could get some if needed? Any idea how long its been below half. DEF is cheap.
I will be going by stores that have it and I can stop and get some. I'm not sure how long it's been below half. I haven't gotten into the habit of checking yet. I towed a TT about 600 miles with it over memorial weekend. I will probably just pick some up and keep it with me just in case.
You will get a 500 mile warning. Then a 200 mile. At some point when you get closer to empty it will begin a countdown. So, you have plenty of warning giving you lots of time to get DEF. On mine the display simply tells me "below half full".
I got that on my way down from Alaska... At the next hotel I dumped my 2.5 gal jug in and then it went back up to DEF level Full. I topped off about 1,000 miles later when I happened to stop at a fuel station that sold DEF at the pump and refilled my 2.5 gal jug. Granted, I still have another potential 10k miles to drive before I make it back home...
I get wanting to take advantage of the maintenance plan you bought too... So I'd probably try to make it back unless I missed it and you have 3k miles to get home.
An average base line to consider is 1000 miles per gallon of DEF. 5 gal tank = 5000 mile radius.
I was wondering if there was an average miles per gallon. After looking at the amount of miles I've driven I realized that I'm only 2K miles from needing to change my oil anyways so it only makes sense that it would be below half. Glad to hear about the alarms at different mileage intervals as well. I guess I was just concerned it would just go into limp mode with no warning at all. I made it home without any issues and now I'm not so concerned about it.
2 things, try filling it again after a drive and make sure you are filling on level ground.
second, sometimes it takes a few drive cycles to reset.
If After that you are still in the countdown to walking, you may have to get the system reset by the dealer, uunless we now have a way to do it with forscan that I'm unaware of.
