Sliding Window Parts
Old Jun 6, 2017 | 08:11 AM
Catchad's Avatar
Catchad
Does anyone have the diagram and part numbers for the OEM rear sliding window in a 86 F150? Mainly looking for the felts and rubbers. I know there is an aftermarket window available but trying to keep the factory window. Thanks.
Old Jun 6, 2017 | 09:59 AM
FuzzFace2's Avatar
FuzzFace2
I need them also but I have not seen them any where but also have not gone looking just for them.
I would think if you find them it may be as much as a new window assy. and why I will go new.
besides if you did not get the truck new and are sure dealer did not install after market one how you know it is a ford unit?
Dave - - - -
Old Jun 6, 2017 | 10:13 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Factory units are the thickness of the track and use a different rubber gasket.
Aftermarket units have a thin flange and use the single pane glass gasket.
Old Jun 6, 2017 | 02:23 PM
Catchad's Avatar
Catchad
Dave - - - -
Yeah I've found a few pieces I think and I'll probably have it what a whole aftermarket assembly would cost but would just rather keep the OEM.
I know its factory because it was there off the lot and has the wide flange and carlite glass.
Old Jun 6, 2017 | 02:48 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Numberdummy has posted the p/n for the track liners before.
I'm on my phone, so I'm not going to search for it.
Old Jun 6, 2017 | 05:16 PM
WhatsAChevy?'s Avatar
WhatsAChevy?
I have two rolls of adhesive backed 3M Velcro (side-by-side) and used the "soft" side to line the tracks of my rear slider as well as both cab door window runs/tracks. Rattles and wind noise are gone.
Old Jun 6, 2017 | 06:52 PM
CountryBumkin's Avatar
CountryBumkin
Here's the link to my thread where I was looking for parts for factory slider. There may be some useful info there. https://www.ford-trucks.com/forums/1...ng-window.html
Old Jun 7, 2017 | 08:41 PM
Catchad's Avatar
Catchad
I found some parts numbers at Tasca Fords website. They have the illustration of the window and what I guess would be original part numbers. Then found most everything at Green Sales. Some of the parts are questionable in that the illustration doesn't clearly show each component and the part descriptions are not the most helpful. Will report back when I get what I ordered.
Old Jun 11, 2017 | 09:48 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Mainly looking for the felts and rubbers (Ford: Runs & Seals).
1982/91 F100/350:
E3TZ-10422A20-B .. Lower Sliding Back Window Run / Obsolete
HUNT FORD in La Plate MD has 1 = 301-870-3025.
GREEN SALES CO. in Cincinnati OH has 11 = 800-543-4959.
1982/88 F100/350; 1989 F150/350 before production date 11/88:
E3TZ-10422A36-A .. Upper Sliding Back Window Run / Obsolete
No Ford dealer or obsolete parts vendor has any.
1982/91 F100/350:
2) E8TZ-10422A68-A (replaced E2TZ-10422A68-A) .. Seal-Sliding Back Window-Side / Obsolete
RPN PARTS in McKean PA has 2 = 888-666-0916.
BAYER FORD in Comanche TX has 2 = 325-356-2777.
GREEN SALES CO. has 4.
Old Jun 29, 2018 | 07:09 PM
gtanns's Avatar
gtanns
How bout this one guys> ?
I lost the driver side of the sliding window piece that connects in the middle.. Was this ever even replaceable ? wondering if I just have to find a donor truck and snag this piece or if this can be found somewhere?
I don't have an OEM parts catalog, so unsure.. Any pointers would be helpful!
I've attached a pic of the passenger side piece, that i still have. The driver side slipped off going through some rough terrain and slipped out between the cab and pickup bed.
Old Jun 29, 2018 | 09:04 PM
FuzzFace2's Avatar
FuzzFace2
Truck Parts and Truck Accessories
I have not gotten far enough to deal with any of the glass on my project yet.
Dave ----
Old Jun 30, 2018 | 01:44 AM
NumberDummy
Please, when asking questions, list ALL the pertinent info, we are not mind readers.
Your "About Me" profile: 1980 F150. If this is what you're working on, here's the correct pic.
Old Jul 2, 2018 | 10:32 AM
Jghake's Avatar
Jghake
I have the same style bar on my sliding window. I bought a new latch to replace the broken one but the screws holding the latch in broke off and won't come out. I was able to find new bars at a junkyard and am going to put that in instead. Maybe you could find them there? If not I could probably send you my old ones and you might be able to get them to work better than I could.
On a similar note, how do I reinstall the bars back on the window so they don't just fall off?
wicat3
Jul 25, 2013 06:49 PM
Fordman_Evs
Jun 23, 2006 02:33 AM
AerostarDad
May 23, 2004 10:14 AM
neikorott
Feb 24, 2004 04:33 PM
nitro94
Dec 28, 2002 10:40 PM
