DASH CLUSTER WOOD GRAIN BEZEL
Good luck to you! That one is the very rare bezel with the fog light switch. And, it is a Rosewood bezel, which was used from 1980 through 1984. But, since it doesn't look like the fog lights were offered in '84 that is an 80-83. And, the 1980 version is different than the 1981-83 version as the order of the warning lights at the top is different.
Anyway, you can find the part numbers here, and the go Googling for it: Instrument & Radio Bezels - ???Gary's Garagemahal.
You just missed an auction for a NOS rosewood woodgrain bezel like the one pictured except not fog light switch bezel. The starting bid was very high and the auction closed with no bids. I expect it will be re-listed, or you might want to contact the seller about it... but it is certainly not inexpensive:
NOS 1980 1986 Ford Truck DASH INSTRUMENT PANEL BEZEL w/ A/C VENTS Original OEM | eBay
Light order difference?
thanks for all all the good info you always provide! I actually have the exact same bezel with the fog switch that pictured above (I have the switch too), what is the difference in the lighting order from left to right in the 80?...
thanks!
Isaac - According to this post:
I have a NOS 80 mesh weave non a/c fog light bezel I'll post pics of tomorrow. The reason why 1980 had its own bezels was because of the location of the turn signal indicators. 1980 had them right next to the high beam indicator, and in 1981-1986 the e-brake and seat belt indicators were next to the high beam indicator. That is part of the reason why a 1980 gauge cluster won't work in a 1981-1986.
Isaac, one thing to keep in mind regarding the 1980 vs. 1981/up indicator lights is that it is quite easy to re-pin the connector that plugs in to the back of the cluster. You un-clip a plastic retainer and you can move the wire with contact pin to the desired slot. In other words, it is no big deal to wire the truck for the year of bezel that you have.
Vemax, if the NOS piece does not come through for you and you have to refurbish used bezels, you might want to take a peek at how I freshened mine up:
https://www.ford-trucks.com/forums/1...project-2.html
Vemax, that looks very similar to my 1982 F150 parts truck with dealer installed AC. On mine, the pocket was sawed off and a switch panel was installed there just like yours except mine has markings. Holes were also cut on either side of the cluster for add-in vents. It's hard to tell from your pictures but I think yours are the same way. If you get the NOS woodgrain bezel you will have to decide whether to cut out the pocket or relocate your climate control *****.
Edit: I might still have that control **** panel if you want a more "stock" look.
that would be great , ive been looking around for one but no wrecker seem to have them.
it looks like then the dealer in Australia installed the air con , but I just don't know for sure.
if I do replace the cluster (ebay seller wont respond to my emails) ill relocate the ***** and plate
please let me know if you can get your hands on one.
cheers
cheers
o2outlaw93
11-25-2005 10:05 AM
