Dash Lights - 75 F100
Old Oct 29, 2012 | 07:27 AM
eladnermai's Avatar
eladnermai
I need help with my dash lights. I have a 1975 F100 XLT. The dash lights do not work when the headlights are cut on, but, when the the light **** is turned to the left (turns on the interior dome light), the dash lights cut on. Any ideas of the problem. I was thinking of just replacing the light switch, but, decided to check here first. This is my first time posting on the forum, but, have been lurking for about three weeks since I purchased my truck. I appreciate any help.
Old Oct 29, 2012 | 10:01 AM
fmc400's Avatar
fmc400
MSEE
You're on the right track. If the dash lights are able to come on at all with the headlight switch, then you've proven out the dash light wiring, fuse, instrument panel, and bulbs. I would go ahead and replace the switch. The rheostat in the switch wears out over time and what you're seeing is very common.
By the way, welcome to FTE!
Old Oct 30, 2012 | 01:53 PM
lbumpers's Avatar
lbumpers
Qeustion
Was this all of you dash lights or only the instrument cluster? I noticed a similar if not the same thing on my project truck when parking it last Friday. I didnt think to turn the interior lights on with the switch though. I have lights on those switches and on the heater controls but none on the instrument cluster. I have to check the switch next time I go up to work on it (90 miles away at my parents house).
Old Oct 31, 2012 | 06:59 AM
fmc400's Avatar
fmc400
MSEE
If you have dash lights but no instrument cluster lights, then these are the possible causes:
1. Loose connector going to instrument cluster
2. Bad printed circuit on back of cluster
3. Bad bulbs (only 2)
4. Dirty contacts
In your case, the headlight switch, wiring and fuse are fine since your heater controls are lit up (they are all on the same circuit).
jrotten67
Jan 29, 2017 11:52 AM
johnzmur
Aerostar
19
Mar 20, 2015 07:00 PM
joe f350
Jul 1, 2010 08:42 PM
CoachRobb
Electrical Systems/Wiring
Apr 11, 2004 06:20 PM
thedettras
Dec 1, 2003 11:53 AM
