Front cab mounts
Old Jun 5, 2017 | 06:30 PM
kenny nunez's Avatar
kenny nunez
Front cab mounts
I just spent the better part of the afternoon removing the front cab mounts. I went through 3 spot weld cutter bits . I can see why they do not hold up as there is no paint any where under them. Mine were still solid but on the area under the rubber mounts there was a lot of pitting. I hope D C has them in stock.
Old Jun 5, 2017 | 06:42 PM
JEFFFAFA's Avatar
JEFFFAFA
While you're at it are you making room for a Coyote 5.0L?
Old Jun 5, 2017 | 09:13 PM
kenny nunez
Cab mounts
The Coyote has already been pre fitted, I made a new "B" crossmember. I have 1" billet spacers between the frame and crossmember. Nothing near the level of the Hackster project just the best I can do with what I have and what I can do.
I was able to mount the fuel pump in the stock tank. I still have a long way to go but maybe by the fall it might be rolling.
Old Jun 5, 2017 | 10:18 PM
orich's Avatar
orich
OK Kenny you know we want to see what your doing. Well, I do at least.
I painted the inside with por15 the best I could and bolted mine in with fender washer an ss 1" bolts nylon lock nuts.
Orich
Old Jun 6, 2017 | 07:21 AM
Brian1971f100's Avatar
Brian1971f100
DC should have them. Fitment might not be great. If you can get them in 2 pieces they will fit much better. Good luck.
Old Jun 6, 2017 | 07:59 AM
kenny nunez
Cab mounts
From the pictures it appears that they are spot welded together. I will probably do a combination of plug welding and bolting them back on. A body man owes me big time and said he will help me getting them back on. I will try to post a few pictures of the carnage later today.
Old Jun 6, 2017 | 12:22 PM
JEFFFAFA's Avatar
JEFFFAFA
Orich
Heck yeah. I'll 2X that motion.
f100today
May 28, 2016 08:07 AM
hitchpin1
Large Truck
Jul 1, 2011 09:44 PM
seventyseven250
Sep 22, 2006 06:32 PM
1ole4d
Aug 8, 2006 10:05 PM
WOFP
13
Jul 2, 2006 09:50 PM
