Cab Mounts
Old Apr 9, 2006 | 08:13 PM
WOFP's Avatar
WOFP
Question Cab Mounts
I just bought four cab mounts from LMC Truck to install. They are of two types. I am unsure which ones go forward and which pair goes aft. Who can help? And thanks in advance.
Old Apr 10, 2006 | 08:10 PM
Nod's Avatar
Nod
Cab Mounts
WOFP,are you talking about the sheet metal mounts under your feet at the cab floor? There are only two,one on the left side and one on the right side.You should have one left and one right side and that's all.
"bowties in the rearview mirror"
Old Apr 10, 2006 | 08:51 PM
WOFP's Avatar
WOFP
Question
I have four cab mounts to install; two at my feet and two just under the rear of the cab near the fuel tank. The mounts are different, depending on location. I'm not sure which pair goes in the front near my feet, and which are installed aft. Also, does anyone have one or two time-saving tips?
Old Apr 10, 2006 | 09:31 PM
bcam69's Avatar
bcam69
WOFP - Are you talking about the rubber mounts that go between the cab and the frame?
Old Apr 11, 2006 | 06:25 AM
jowilker's Avatar
jowilker
WOFP, The mounts are visiable from under the truck, check it out and it will become as clear as mud to you.
John
Old Apr 11, 2006 | 09:18 AM
jor's Avatar
jor
I am also a little confused by your question because, as others have said, there are two cab mounts for the front corners but the cab bolts directly to the frame on the back. Here are two photos. The first shows the front mount and the second, the rear. You can see the rubber cushion on the rear with the bolt mounting to the frame. The bracket you see under that is for the cross member. I can get you some better photos tonight if you need them.
jor
Old Apr 11, 2006 | 02:44 PM
f100tk77's Avatar
f100tk77
I have a 77 f100 and im currently working on taking the cab mounts off. I started with the rear mounts and was able to get the bolt out but for the life of me i cannot remove the bushing the lower bushing under the frame has the nut that welded to the bushing as far as i can see that runs up threw the top bushing. but i can get either of them off after taking the bolt out. any help would be great thanks...
Old Apr 11, 2006 | 09:53 PM
Ford_Six's Avatar
Ford_Six
The lower bushing has an extended tube going up through it, that is threaded on the inside. This tube tends to rust into the upper bushing, and needs to be knocked out or cut apart. I have used a sawzall and a hacksaw to seperate these before, as well as knocking the lower part through with a punch.
Old Apr 12, 2006 | 06:17 AM
WOFP's Avatar
WOFP
Smile
Jor and all-thanks for the photos and advice! I plan to lift the cab and end at a time and install each pair. Seems like all I have to do is raise the cab a couple of inches to free the old bushings and replace them. The pix did the trick...
Old Jun 11, 2006 | 08:29 PM
71 Sport Custom's Avatar
71 Sport Custom
Wofp, Did you get your mounts installed? Did your mounts include the new steel pieces? Were core support mounts available? Were you happy with the mounts? Thanks, Douglas
Old Jun 24, 2006 | 09:59 AM
WOFP's Avatar
WOFP
haven't had time to install yet. ordered from LMC Truck. four steel bolts with double rubber gaskets each. looks simple to do if i can pry old bolts out
Old Jul 2, 2006 | 05:04 PM
WOFP's Avatar
WOFP
Today, I located the top of the right front mount by unscrewing the access plate just forward of the mount in the wheel well. I tried to jack the housing up in order to separate it from the cab and allow me to knock the lower rubber gasket out. I was unable to gain that separation. I did not want to keep jacking and have the lower part suddenly fall down, so I just eased the whole thing back down. Do I need to jack both sides simultaneously? Anyone have experience doing this?
Old Jul 2, 2006 | 05:36 PM
Ford_Six's Avatar
Ford_Six
You have to run a hacksaw or sawzall blade in the top bushing and the mount pedestal to cut the tube, since you can't get in there with a punch.
Old Jul 2, 2006 | 09:50 PM
WOFP's Avatar
WOFP
The right mount has no bolt or tube; the cab is simply sitting on the bushing. What is the mount pedestal? I'm sure the left mount will need some horizontal sawing...
