ECU/PCM opinion
Old Jun 10, 2017 | 09:12 PM
Conanski's Avatar
Conanski
Originally Posted by Thinlizzy13
Followed the lines back and the in tank fuel pump isn't putting out anything, but I can hear it working.
If you had to splice wires to put the new pump in then it's easy enough to wire it backwords which would make it suck fuel into the tank instead of pushing it out.
Old Jun 12, 2017 | 07:55 AM
FarmTruck93's Avatar
FarmTruck93
I've seen some DIY'ers accidentally reverse the polarity on the pump motor. Sometimes the Spectra brand fuel pumps color codes get a little confusing. I'd double check the hookup. Even the best of us get wires crossed sometimes.
Old Jun 12, 2017 | 09:46 AM
Thinlizzy13's Avatar
Thinlizzy13
That's probably what I did. I rushed to get it back together and should have tested it before I put the tank back up. You can bet I won't do that again.
Old Jul 1, 2017 | 05:34 PM
Thinlizzy13
Just to follow up, I did get the wires backwards on the pump. I switched the wires outside of the tank and all is good now. Thanks everyone. On to tank 2!
jergar4
Apr 27, 2018 05:18 PM
MKLC
44
Mar 31, 2016 06:26 PM
Canyonrunner
1997 - 2003 F150
Jan 15, 2013 07:22 PM
guiri
Aug 22, 2007 08:27 AM
dsthubbins
30
Jun 16, 2007 10:16 AM
