Transmission seal where it meets u-joint?
How many miles? Extension housing yoke seal can wear out because the bushing that supports the yoke has rounded out. If so, a new seal will last for a bit, then when the rubber wears bigger, it will start leaking.
The output bushing can be replaced with the extension housing staying on the truck by using a special internal grabber with slide hammer.
I have replaced trans output bushings by removing the extension housing, and very carefully hacksawing (blade holder handle type) two flat parallel grooves near each other, then carefully peeling the bushing piece between out with a small punch on the edge of the bushing. Once the piece is removed, the bushing comes right out. If you do it yourself, note where the oil hole is in the bushing, new one needs to fit over the oil groove, and set it to the same depth in as old, if there is no stop in the casting.
I have a press, so I can just press the new one in using a piece of board to get it started flat, and once is gone in so far as to hit the housing, switching to a piece of pipe, or whatever fits best as the push piece. Can do same with a mallet.
I pulled the extension housing off my transfer case and brought it to a good shop along with the replacement bushing. He pressed the old out and new in for $10, that day. The seal itself is super easy to change. While the driveshaft is out, check out u joints.
Its probably a lot more if you bring the truck in, bc then they have to take the time to lift the truck, remove driveshaft, remove tail housing, remove seal, remove bushing, and then reverse all of that. So, if you have a second vehicle or a ride, and can pull the driveshaft and tail housing yourself, can likely save money. Your statement about needing a shop is a bit vague in what you need the shop to do, so I wanted to clarify.
What search term do I use on eBay for the part I need? Maybe a dumb question... I reckon I could figure that out.
