Transmission temp
Old Jun 5, 2017 | 01:34 AM
Bigb6.0's Avatar
Bigb6.0
Transmission temp
What is the average temp the transmission runs at? Wondering because it slipped the other day and the fluid smelt like it was burnt almost. Wanting to monitor it on my scan gauge and just try to ride it out as long as possible..
Old Jun 5, 2017 | 02:14 AM
Blakshukvw's Avatar
Blakshukvw
Mine stays relatively close to my coolant temp.
Old Jun 5, 2017 | 02:20 AM
Yahiko's Avatar
Yahiko
You might want to go and edit the subject line to have the word slip in it.
To change the subject line >EDIT>Go Advanced.
Then you will be able to edit the subject line.
I think you will find you get more responses that way.
Old Jun 5, 2017 | 07:43 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
There is a thermostat in the transmission that tries to keep the trans at 165-170°F.
Old Jun 5, 2017 | 10:28 AM
Yahiko's Avatar
Yahiko
BINGO!
We got the one guy that can asnwer questions about the 5R110W the best.
Hi Mark.
Old Jun 5, 2017 | 01:22 PM
silverbullet6oh's Avatar
silverbullet6oh
wow that is interesting.
mine would typically stay between 145 and get above 175 makes sense knowing that there's a thermostat
Old Jun 5, 2017 | 01:31 PM
LCR's Avatar
LCR
Hey Mark is still around!!
Old Jun 5, 2017 | 03:08 PM
IABill's Avatar
IABill
Wink
No load CC set @ 70 Torque pro says 154 to 160 max.
Towing toy hauler 180 or so on flat-land T.C. locked
Hills, add 15 to 20deg.....
Old Jun 5, 2017 | 03:18 PM
Mark Kovalsky
I haven't gone anywhere.
Old Jun 5, 2017 | 05:39 PM
69cj's Avatar
69cj
How many miles on it and was the proper maintenance, fluid and filter used? Need more info.
Old Jun 5, 2017 | 10:42 PM
Bigb6.0's Avatar
Bigb6.0
Thank you! If the scan gauge is correct it was running around 160 degrees on a half hour drive home tonight. Is that temp still okay?
Old Jun 5, 2017 | 11:32 PM
Yahiko's Avatar
Yahiko
Yes.
Old Jun 6, 2017 | 07:27 AM
Mark Kovalsky
Yes, that's fine.
Old Jun 6, 2017 | 11:01 AM
diesel_dan's Avatar
diesel_dan
I blew past this 1st time through this thread. But that is pretty warm... If by chance you are getting that reading off of Torque, there is a problem in the PID for the Trans Temp. You need to edit the Gauge, drop down to OBD Header and change it to TCM from Auto. It will then read the correct trans temp.
Unless your coolant reads super low???
Hope it is the header thang...
Scott
Old Jun 6, 2017 | 07:07 PM
2006powerstroke90's Avatar
2006powerstroke90
I won't argue with Mark in the slightest bit, but from what someone told me once, and they could be and are probably wrong 100* + ambient air temp is normal.
Mark....any input?
