F1 front hub grease?
JB
Both the shop manuals, and Timken, SKF etc say to fill the hub with the same wheel bearing grease till it is even with the (smallest dia.) bearing race, and a light coat on the spindle. That is a few handfuls worth easy.
My theory is that it is put there to prevent the hub from retaining water in case of fording. Grease doesn't flow much if at all from what I've seen. They say it does help retain grease in the bearings. I spose! Some texts from Brand X or Y say to fill the dust cap halfway too.
You don't need a machine. Just use the palm of your hand. Here they are wearing gloves but IMHO I find them unnecessary.
How to pack wheel bearings
Grease is oil suspended in a spongy medium, it does flow. You just don't realize how little lubricant it takes to keep everything happy. I can't begin to tell you how many times I've seen guys that should know better only pack the cones and not the cavity. Old farts used to bark, "Make sure you get grease in between all the rollers" and then not pack the hub. I can tell you all the grease between the rollers will get squished out in a few hundred feet and and slung out from centrifugal force in less than fifty miles. That grease between the rollers will collect in the empty cavity and never again reach the bearings.
redbug
04-30-2009 10:56 AM
improvement54
12-05-2006 10:49 PM
SoArkSI
10-17-2006 10:03 AM
