need help with tail light harness plug/trailer light harness
I m trying to install a trailer light kit that plugs into the factory taillight harness so that I will not have to cut up the factory harness . Problem is that I can't get the tail light harness plug apart to install it . Is there a trick to it or a tool that is needed ? I was pulling hard enough that I worried that it was going to break so though i should ask .
https://www.etrailer.com/Custom_Fit_...ha/118313.html that is what I am trying to install .
Got it done without breaking to much of it . I cut a couple small pieces of plastic from the hang tag for a single socket and filed them down . Pried up the tabs carefully and wedged them open . Pulled right apart . Did break one side of one of the clips but better than how it typically goes .
I noticed while checking the trucks lights that the drivers side turn signal is a good bit slower than the passenger side . It is the same speed for one or two blinks then slows down . Not sure if it was like that before but i don't think the trailer light harness would cause that .The left side dash indicator has been burnt out for years, would that have anything to do with it ? I have new bulbs but can't get the head light and washer ***** off to get the gauge cluster bezel off . I looked up how to do it and they are not built the same way it seems . There is no clip on the washer **** and no button to release the head light switch or a clip that I can find .
Greg5OH
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
08-26-2015 08:27 AM
smashclash
01-23-2011 01:53 PM
jjbourne
11-27-2010 02:38 PM
