96' F150 Trailer Lights-Mangled Mess-Help!
Old Nov 27, 2010 | 01:51 PM
jjbourne's Avatar
jjbourne
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> 1996 f150xl 6cyl
I want to hook up a simple four pin plug to tow a small trailer. I wish I could have made this easy and bought the plug in adapter. It seems the previous owner decided to cut all the factory plugs off and rewire the tail light wiring while tripping on acid... what a mess. About 2 rolls of electrical tape and 10 feet of lamp cord later.....
Amazingly the lights in the truck work, but I have no clue what does what? Anyone know the color coding for the wires or have a wiring diagram? I spent a lot of time searching the forums, but I didn't find anything that spells it out in small words so I could follow it... thanks for the help!!
Old Nov 27, 2010 | 02:02 PM
aguitarestv's Avatar
aguitarestv
are there any factory plugs left on the lighting harness? if so you might just want to go to a junk yard and pull the harness to make it plug and play so to speak.
Old Nov 27, 2010 | 02:38 PM
danr1's Avatar
danr1
This should be the wire colors for your truck,
Tail light = Brown
Right turn/stop = Orange light blue
Left turn/stop = Light green orange
Ground = Black
Reverse lights = Black Pink
Yea I agree, if the factory plug in still on the end of the main harness, the connector the tail light harness plugs into, might be better/faster/easier if you can get a tail light harness from another truck. Get rid of the lamp cording etc, then pick up a t harness for the four pin trailer plug. Makes it all nice and water tight the easy way, if not be sure and flux/solder any splice connections you gotta make back there.
BDB513
Jul 21, 2014 04:38 PM
JPs2003
28
Mar 5, 2012 10:15 AM
hanke777
1978 - 1996 Big Bronco
24
Mar 1, 2011 03:07 AM
nepatriots
Escape & Escape Hybrid
Oct 29, 2010 11:19 PM
mvedepo
6.7L Power Stroke Diesel
Oct 5, 2010 11:42 PM
