Bed crossmember question
Old Jun 3, 2017 | 05:35 PM
tigerfan79's Avatar
tigerfan79
If this is a stupid question I apologize in advance (I've been in the shop way too long today). I'm bolting the two center crossmember to the frame on my 51 and using the bolts supplied in the kit (Midwest early Ford) I'm not sure the correct way. Do these go from under the frame through the crossmember and then somehow get a wrench inside the crossmember to hold it to tighten? Or, do they go from the top which in this case I need longer bolts.
Thanks,
Matt
Old Jun 3, 2017 | 06:14 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Those are held down by the big bolts in the boards.
Old Jun 3, 2017 | 06:24 PM
underthebridgejim's Avatar
underthebridgejim
FTE fan
I think this may be what Ross is talking about.
mid xmember
Old Jun 3, 2017 | 06:36 PM
tigerfan79's Avatar
tigerfan79
That makes sense thanks. What is confusing is they didn't send long enough bolts to do it that way. This was the only instructions included.
Old Jun 3, 2017 | 07:37 PM
schoo's Avatar
schoo
Here is a material list that northern classics had with my bed
They use a sub frame so the bolt length may not matchup
Old Jun 3, 2017 | 07:51 PM
schoo's Avatar
schoo
Like I said this is for a northern classics kit
Old Jun 3, 2017 | 07:52 PM
ALBUQ F-1's Avatar
ALBUQ F-1
The crossmembers are held to the frame with these four bolts. ("A" in Schoo's parts list)
Old Jun 3, 2017 | 08:04 PM
tigerfan79's Avatar
tigerfan79
Thank you. I'm throwing away that instruction list. For the front crossmember, it bolts directly to the frame, correct?
Old Jun 3, 2017 | 08:17 PM
ALBUQ F-1's Avatar
ALBUQ F-1
On a '51, yes.
BTW, Schoo's material list/drawing shows two bolts (similar to the 4 and also labelled "A") that don't exist on pre-'51 beds.
armyaviation
Oct 26, 2017 10:15 AM
diablodude64
13
Mar 30, 2012 05:19 PM
learpilot
Dec 28, 2005 03:44 PM
Scott123
Aug 11, 2005 08:33 PM
mark914
Oct 25, 2002 07:21 PM
