petronix ignition coil
Old Jun 3, 2017 | 08:23 AM
tlb's Avatar
tlb
I have a 1970 302 with the petronix igniter with the petronix flame thrower coil. the coil part number is 40011, 40,000 volts, 1.5 ohms resistance. this coil does not have a ballest resistor built in. I have been running this set-up for approx. 8 years. My question is should I have a ballest resistor with this coil and should I use the 1.5 ohm or 3.0 ohm coil?
Old Jun 3, 2017 | 11:56 AM
Indybeer's Avatar
Indybeer
From Pertronix instructions for 12v neg ground
4. Four and six cylinder engines require a minimum of 3.0 ohms of primary resistance and eight cylinder engines require a minimum of 1.5 ohms of primary resistance. Do not remove resistors if the coil primary resistance is less than specified.
5. If your Ignition coil has the recommended primary resistance, remove or bypass all external resistors.
http://www.pertronix.com/docs/instru...heets/1181.pdf
From that I would say you are good.
Old Jun 3, 2017 | 04:35 PM
tlb's Avatar
tlb
thanks indybeer, that is exactly what I did.
peka
34
May 20, 2015 01:20 PM
78 & 87 Super Cab
Dec 23, 2014 06:32 PM
svp_evo
Feb 18, 2014 10:20 AM
fordboy300
Sep 22, 2013 08:42 AM
abe
Jan 1, 2013 04:51 PM
