EFI Coil question
Old Feb 18, 2014 | 09:37 AM
svp_evo's Avatar
svp_evo
EFI Coil question
Does anyone know, is there any drawback or limiting factors that would stop someone from converting to a standard style coil like the one in the link:
http://www.summitracing.com/parts/msd-8203/overview/
The square style coil is kind of a bitch to mount on the edelbrock monifold. Aftermarket Valve covers are also making it rather dificult. I welded together a larger foot print to mount it to the 2 forward bolts on the upper plenum but it really is ugly as hell. If a coil is a coil is a coil, I think I would rather convert to a cylinder style one for easier mounting.
Old Feb 18, 2014 | 09:45 AM
Franklin2's Avatar
Franklin2
What ignition are you running? A coil is not a coil. Are you running the stock Ford system(TFI or Duraspark II) or a aftermarket system like MSD or Mallory.
Old Feb 18, 2014 | 10:02 AM
Brnfree's Avatar
Brnfree
What Franklin said ^. What ignition system are you running?
IIRC If you're running Duraspark the primary resistance of the coil should be 1.4 ohms, and since the primary resistance of the coil you posted is 0.8 you'd need to run an extra resistor what that particular coil.
Also, the instructions for that coil recommends the coil be mounted vertically, not horizontally.
These canister coils are oil filled and I just replaced one that was leaking...
Old Feb 18, 2014 | 10:13 AM
svp_evo's Avatar
svp_evo
its a 1990 I believe its TFI. As far as mounting. I was just going to move it to the fire wall.
Old Feb 18, 2014 | 10:20 AM
svp_evo's Avatar
svp_evo
I do appreciate the input gents, think I found my solution. I had to swap to a sanden style AC compressor to run the march pulleys. I had to replace the compressor anyhow because it was ceased. BC Broncos
captntim
May 3, 2024 12:36 PM
fordboy300
Sep 22, 2013 08:42 AM
abe
Jan 1, 2013 04:51 PM
DBGrif91
Mar 20, 2011 05:28 PM
kimble
Nov 9, 2010 04:25 PM
