So my full time job is industrial maintenance at a manufacturing plant. I went looking through our orings and found some that looked close.
I'm not sure if the size yet but I did find one that matched. I will get a size and post up for future reference.
Some of you may remember some of my post the past few months with my Miss I had that I couldn't pinpoint to a cylinder and then the minor runaway situation I had. Well I drained the oil out and got well over 20 quarts out and it was thin as crap. So obvious fuel diluted. So I replaced all outer orings and copper washers. Installed the injectors and turned on pump with oil drain plug removed and after a minute I had fuel running out of the oil drain. So I removed injectors and replaced the internal orings and copper washers and that sealed it up.
I believe the internal leaks in the injectors caused a low fuel pressure situation and was causing the miss. I will finish putting truck back together Thursday and see what's going to happen.
The way I traced it to the internal orings is by covering two of the fuel inlet ports with my fingers and using 10psi of air with a blow gun with rubber tip I blew air into the third inlet and bam I saw the fuel followed by bubbles coming from the top of the housing. After I replaced the oring I air tested again and it was good. So installed it back in.
Injector Pintle is shot.
Rerun the test after you stuff the injectors back in
and I will bet you will still get a leak. The only other
place is a crack in the fuel gallery of the head.
I did run pump again after for about 10 minutes and no fuel ran out of the oil pan. Also had fuel pressure gauge hooked up and was showing about 67 psi.
So your saying that you blew air into the tip of the injector while holding the inlet ports on the side of the injector closed.... that showed you have a leak?
Injector has three inlets, covered two and blew into third one.
That said 10 psi in not squat when you consider what they normally run at.
If it works for you goose then good on ya! You might be breaking new ground here.
Injector has three inlets, covered two and blew into third one. That said 10 psi in not squat when you consider what they normally run at. If it works for you goose then good on ya! You might be breaking new ground here.
Checking it with air definitely showed me it was leaking. I regulated the air to 10 psi so I could hold my fingers over the other two ports. After the new oring was installed and checked again there was no leakage.
I promise to have a size of the oring for y'all tomorrow. I also don't some other things with the internals which I'm not going to spread around just yet. I want to see the outcome first before I do.
Was it leaking out the top of the injector? Could you see the fuel leaking with pump running?
I'm asking because I recently did injector seals, top seal and nipple cups and now, 5000 miles later, I've got a leak again... oil pan has a few quarts to many.
