Erratic Ignition Advance Timing
Old May 30, 2017 | 04:40 PM
mavman427's Avatar
mavman427
4wd Low
Exclamation Erratic Ignition Advance Timing
I have a 2004 Lincoln Navigator with the 5.4L DOHC Intec engine. It has 150k miles and it has recently developed a rough idle. I plugged my scan tool in and noticed very erratic ignition advance timing - see attachment. Any ideas why this would be the case? Think the timing chain and/or timing chain tensioners/guides are shot?
Old May 31, 2017 | 12:30 AM
Skauber's Avatar
Skauber
Does this engine have camshaft sensors? As far as I know it doesn't have the phasers, so might not have camshaft sensors either?
Not sure how slack in the chain would cause erratic ignition timings, unless it has camshaft sensors and is reading an erratic valve timing.
Another thing to check might be knock sensor, might even try to unplug it and see if the erratic behaviour stops. The knock sensor has a direct effect on the ignition timing.
Old May 31, 2017 | 12:32 PM
pdqford's Avatar
pdqford
Rough idle is probably causing the PCM to change the timing, trying to match it to the rpm.
Any stored or pending DTCs?
Old Jun 1, 2017 | 09:06 AM
alloro's Avatar
alloro
Erratic or jumpy timing advance is usually a sign the crankshaft position sensor is on it's way out.
Shawn_Laughlin
Modular V8 (4.6L, 5.4L)
Jan 10, 2019 11:29 AM
The Terrible Blob
13
Feb 1, 2014 08:00 PM
Iceland_Man
Jan 8, 2014 10:27 AM
tx64f100tx
Feb 12, 2006 02:37 AM
masonmachines
Jun 30, 2004 09:19 PM
