ignition timing
Old Feb 11, 2006 | 07:43 PM
tx64f100tx's Avatar
tx64f100tx
ignition timing
does anybody know the ignition timing for a 1964 ford f100, exact timing... thanks
Old Feb 12, 2006 | 02:37 AM
Larry_the_handyman's Avatar
Larry_the_handyman
Which engine do you have? Disconnect the vacuum advance and hook up the timing light. Set it to 8 degrees before TDC. Pretty simple. (make sure the timing light is zeroed, if it has the advance **** on the back)
