I have a 67 f250 and am going to replace the turn signal switch. The new switch has 7 wires. I have 7 wires exiting the bottom of the column but there are 5 that go to one plug and 2 going to another. For some reason I was thinking there was only one plug. I know there was a break in 69 and they show a different part number. So there's two plug ins?
C9TZ-13341-C (replaced C5TZ-13341-A & B) .. T/S Switch / Reproduced
1965/66 F100/250 2WD; 1966 F100 4WD; 1967/68 F100/250 2WD/4WD & F350; 1969 F100/250 2WD/4WD & F350 before serial number D96,001.
--------------------------------------------------------------------------------------------------------------------------------------------------------------------- D0TZ-13341-B .. T/S Switch / Reproduced
1969 F100/250 2WD/4WD & F350 from serial number D96,001; 1970/72 F100/250 2WD/4WD & F350.
