turn signal switch replacement
Old Dec 17, 2013 | 03:24 PM
884x4broncoII's Avatar
884x4broncoII
im needing to replace my turn signal switch as just the weight of the turn signal arm pulls the switch down and makes it blink left unless you drive holding the turn signal switch in the middle position. i have one ordered should be in tomorrow so i figured i would get the old one out tonight and be ready to throw the new one in. i removed the steering wheel un screwed the switch when i couldn't find a plug i removed the gear shift housing hoping to find a plug there. but none is to be found. it looks as if you have to fish all the wires up threw the column and new ones back in. to do that you would have to un pin the connector. im hoping someone tells me there is a easier way.
Old Dec 17, 2013 | 03:25 PM
884x4broncoII
74 f-100 automatic trans
Old Dec 17, 2013 | 04:06 PM
fmc400's Avatar
fmc400
MSEE
Nope, the method you've described is how you do it. Yes, it's a pain.
Old Dec 17, 2013 | 04:19 PM
hickory1991's Avatar
hickory1991
Unplug the switch under the dash. There should be a red wedge in the end of the plug. Once the red wedge is removed, use a small pick to release the small tab that holds each wire in. Make note of which hole each colored wire is going in. Once you snake the new switch wires thru column, installation is reverse of disassembly. Push wires into the holes they were removed from, then insert the red wedge.
Old Dec 17, 2013 | 04:45 PM
884x4broncoII
thanks guys for the information, its not the answer i wanted to hear but. i was waiting to see what people had to say before i dug into it any further. i guess its time to start un pinning the conector
Old Dec 17, 2013 | 11:04 PM
77blue's Avatar
77blue
Before you pull the turn signal switch out securely tape all of the wires to a long piece of wire. Then pull the switch wit all of the wires out of the steering column. Then tape the wires from the new switch to the single wire and use that to pull them back down the column. This makes it a lot easier to get the wires down to the bottom.
Old Dec 18, 2013 | 06:11 AM
Ordnance's Avatar
Ordnance
I would suggest a similar method to what 77blue posted. Tape all of your wires to a straightened out coat hanger and use that to run your wires through the column. I'm looking at having to do the same thing myself.
Old Dec 18, 2013 | 02:38 PM
884x4broncoII
got it done, just don't be like me and pull the shifter and everything off hoping to find a plug that **** was a pain in the butt to get back together and it doesn't need to come off.
Old Dec 18, 2013 | 04:41 PM
hickory1991
Glad you got it done. I know all too well about doing things the hard way.
Old Dec 19, 2013 | 08:15 PM
RaulERichardson's Avatar
RaulERichardson
Ensure that you get a diagram correct, many times the wires are so faded and dirty that you can easlly loose track of what goes where
bubblegum
34
Nov 21, 2010 12:58 PM
fordxxx
May 4, 2005 05:25 AM
yz250roost
Apr 20, 2005 04:39 PM
blackeye
1997 - 2003 F150
Jun 25, 2004 11:50 PM
jim henderson
Dec 6, 2002 08:10 PM
