My 1979 Ford F150 351M engine- radiator boils over after about 5 minutes driving. I have put in a new water pump, thermostat, radiator cap, flushed the radiator and this still happens.
Did you check the condition of the bottom hose? They get soft with age and may suck closed, restricting the water flow...Some had a coiled wire inside for support that would rust away...
Has it always been doing this, or did it just start? If it did just start, what happened just before it started acting up? Were any repairs or damage done? Is that 5 minutes of slow driving or highway?
even if they flushed out your radiator.....they should have "rodded it out as well!! If they didn't do this it could still have a significant amount of blockage to cause excess heat to buildup in the system. I would ask the radiator guy if he performed this on Your radiator. sk
One test to try... When the engine is cold, remove the radiator cap (to relieve any pressure) and put it back on. Start the engine, rev it a couple of times and shut it right off. Then loosen the cap to see if there's any pressure build up. If there is, that would mean that combustion pressure is getting into the cooling system. Either a blown head gasket or cracked head.
The motor has been head tested. There are no combustible leaks. When the motor is running, with the radiator cap off, the coolant doesn't move. I tried all the suggestions. It's not any of them. I'm beginning to think it is the radiator-the rad is bad. It is 8 years old. Thanks for all the info. I
