250 Degrees
Old Mar 16, 2012 | 01:12 AM
maddogjohnson's Avatar
maddogjohnson
250 Degrees
My temperature gauge shows this as the normal operating temperature of my 460 motor.
Before this was the norm, the truck overheated in 30 degree weather when the thermostat got stuck and I started driving in the hills. I replaced the thermostat with a 195 and have run the truck in weather from 5 degrees to 75 degrees since that day and it still registers the same ~250 degrees.
The radiator does not boil over, it holds pressure fine. I am not sure how many pounds my radiator cap is and my truck is not close by right now to check. Assuming I have a 15 pound cap and a 60% antifreeze mix with water, I believe my boiling point would be about 270 degrees. Does that sounds right?
So am I constantly running in the danger zone and begging for a serious problem to occur? Could I have cooked the temperature sending unit when it overheated and now I need a new one? Any other theories?
Old Mar 16, 2012 | 05:38 AM
Blue and White's Avatar
Blue and White
That's kinda hot. As a first low cost diagnostic, I'd add another guage or replace the guage/sender to determine if that is a true temp.
Old Mar 16, 2012 | 09:14 AM
mark a.'s Avatar
mark a.
A mechanical gauge is pretty much fool proof so I wouldn't think it is wrong. I would put a radiator psi checker on it and see what happens.
Old Mar 16, 2012 | 06:40 PM
YZ250rider's Avatar
YZ250rider
I had the same happen too my 78 400 ended up being the radiator not flowing enough coolant.
Old Mar 17, 2012 | 10:25 PM
maddogjohnson
Thanks for the thoughts so far. I'll flush out the radiator and see if there's a noticeable difference after that. That's something I need to do anyway.
Old Mar 17, 2012 | 10:38 PM
ChiefM's Avatar
ChiefM
Do you have a shroud around the fan?
Old Mar 19, 2012 | 12:43 AM
maddogjohnson
I little piece of it is broken off, but yes, I have a fan shroud.
Old Mar 19, 2012 | 06:06 AM
Poison Oil Racing's Avatar
Poison Oil Racing
I wonder if when it overheated it dislodged something in the system and now there is some gunk blocking the coolant from flowing properly in the radiator. If there is a radiator shop near you take it to them and have them boil it out. The shop by me charges like $25.00 to do that.
Old Mar 19, 2012 | 08:46 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
I find it hard to believe that is accurate. Oil pressure would have to be down and probably smoking. Dipstick too hot to even touch without burning you. If you know anyone with a infrared thermometer, read the inlet/outlet hose temps.
Old Apr 5, 2012 | 12:29 AM
maddogjohnson
I haven't looked at my truck in a few weeks, but I got out to take a look at it today.
With the engine cold (sitting for weeks without running), the temperature gauge says 210 degrees, so I know its bad.
I have another temperature gauge that I'll stick on it, and that should be the end of this little saga.
Old Apr 5, 2012 | 12:33 AM
ChiefM's Avatar
ChiefM
Glad to hear it is something simple.
Old Apr 5, 2012 | 04:17 AM
dulockdrumheller's Avatar
dulockdrumheller
temp reader
Ok well as far as I know you can pick up a laser temp reader at harbor freight for $29. That should at least give you a true test of your engines heat.
Old Aug 10, 2012 | 05:46 PM
maddogjohnson
Ended up getting a harbor freight special and it confirmed that the operating temperature is 180 to 190. I still need to replace the gauge
Old Aug 11, 2012 | 01:28 AM
Thunderjet4x4's Avatar
Thunderjet4x4
+1 or many on the laser temp. guns, always double check, or more. I put a known used electrical guage/sender on my bigblock, it is reading high, which worried me to no end, until I checked with a couple of different laser guns, to be sure.
Thought it was hot, it was just right!
I checked intake water passage, sending unit, thermostat housing hoses, rad, cylinder heads, etc.
Makes me wonder about all guages, let alone the factory one.
Going to try and "adjust" my electrical temp guage with a potentiometer. The guage is made by VDO. And carry a damn laser temp. gun.
ollirrap
22
Dec 22, 2014 10:11 AM
rottenstock
Jul 29, 2013 10:52 PM
cvaday
Jul 3, 2011 03:11 PM
nsshull
Jun 30, 2007 08:30 PM
G Guess
Dec 12, 2006 05:39 PM
