Possible torque converter failure?
Old May 26, 2017 | 09:48 AM
mully31's Avatar
mully31
2009 F150, 6R80 Tranny, 110,000 km's.
After truck is hot, when I stop the truck then shift to reverse, the engine sounds like a diesel engine and like it will possibly stall. When I give it gas the noise/rumble stops. When I shift to forward I does it very slightly then goes away. Doesn't do this every time and It seems I can go a few days to a week without it happening. Seems to occur more after driving on bumpy dirt roads at higher speeds (80km/hr)
Old May 26, 2017 | 11:36 AM
rick patton's Avatar
rick patton
I think you might be having the same issue as I am. If you have one of the 3v titans ,It's not the torque converter at but probably the VCT selenoids or phasers going bad . What motor do you have. Just my opinion though. Easy to check though
Old May 26, 2017 | 01:13 PM
mully31's Avatar
mully31
5.4L V8 Engine. The dealership just changed a solenoid due to the engine light being on. I will have to go back and look to see if it was the VCT Solenoid
Old May 26, 2017 | 02:00 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The trans will do this if it is low on fluid.
Old May 26, 2017 | 02:46 PM
rick patton
Unplug your vct' sand run it for awhile and see if it does it.
jbravata2
Nov 20, 2014 07:05 PM
PW01
Jan 4, 2009 07:54 PM
UP_There
Dec 23, 2007 07:24 PM
pborgm
1997 - 2003 F150
Aug 11, 2006 10:24 PM
disaa
Aerostar
Apr 19, 2004 07:56 PM
