Sponsored by: Auxito
Torque Converter??
Old Aug 11, 2006 | 12:25 PM
pborgm's Avatar
pborgm
Torque Converter??
Hi - This is my first post. I have a '98, 4 X 4 w/ the 5.4 Liter engine and about 112,000 miles.
When under load, there is a clacking noise coming out from under the truck. It is not the engine because it doesn't do it going downhill or in neutral. There is also a rumbling (don't know how to describe it - it's not loud but you can feel it in your feet) when, for example, I take my foot off the gas at 70.
I figure it might be the torque converter. Does that sound right?
Anyway, the torque converter dust plug is missing, don't know for how long. Could that have caused some trouble?
Will replacing the tranny fluid fix the problem (if it is the converter?)
Thanks for your input...
Paul
Woodstock, CT
Old Aug 11, 2006 | 09:36 PM
Ultramagdan's Avatar
Ultramagdan
Hello pborgm and Welcome to FTE!
Are you sure the u-joints are ok? They can make quite a racket when they go bad. No, I don't think the dust cover would play a part in this.
Old Aug 11, 2006 | 10:24 PM
pborgm's Avatar
pborgm
Thanks for the reply. The U-joints were replaced not too long ago...
No, this problem is definitely related to RPM; the clacking increases in frequency as I accelerate.
