EEC vacuum diagram questions
Old May 28, 2017 | 02:25 PM
  #61
vjsimone's Avatar
vjsimone
And a port on top of the carb like that is not going to have manifold vacuum, which is required to make the choke pull-off work.
True the "C" and the "V" do not connect directly to Manifold Vacuum.......
See pages; 7, 16 & 38 of this document; Motorcraft 2700 7200
Free Carburetor Manuals
Select; Motorcraft 2700 7200 document
Old May 28, 2017 | 03:11 PM
  #62
vjsimone's Avatar
vjsimone
Originally Posted by KULTULZ
Also-
What I think is going on...
CM supplies full manifold vacuum to the actual choke motor pull-down (styles vary w/ application)
This does make sense....
Old May 28, 2017 | 07:45 PM
  #63
KULTULZ's Avatar
KULTULZ
Post
This particular 7200 VV illustration/application shows a choke housing cooling air source (hose from air horn -clean filtered outside air) to choke motor to keep cool the electric choke cap.
There must be variations on this particular design with differing applications.
THANX! for the VV Manual reference...
Old May 28, 2017 | 08:16 PM
  #64
Franklin2's Avatar
Franklin2
I think you are correct, that high up hose connection is for filtered air. I am not so sure about your "cooling air source" description. They way it usually works, they have a controlled vacuum leak leading to the round black choke housing. This sucks air through the choke housing, and the source for the air is usually from the exhaust manifold or some other heat source. Of course the air has to come from somewhere, and they usually get it from up high on the carb around the air horn.
On the carbed pictured above, I would be curious to see what it looks like underneath the choke pull-off area. I would not be surprised to find a port leading to underneath from that hose, and some sort of tubing or some sort of heat stove under there and then another pipe leading up to the round choke housing.
Admittedly I know nothing about the original poster's questions, and know nothing about the carb pictured above. My comments are from what have have seen as the common way they do things with most of the choke systems on different brand and kinds of carbs.
Old May 28, 2017 | 08:36 PM
  #65
KULTULZ's Avatar
KULTULZ
Post
What you are describing is the older choke stove design where the choke cap spring was heated by hot air from the exhaust manifold. FORD went electric cap with oncoming emissions regulations.
The choke design on the VV (also carbs of the period) used this to prevent the CM from overheating and may have allowed choke modulation.
I don't know how the discussion went to VV CARB either but I have learned and shook a few cobwebs loose...
Old May 28, 2017 | 09:53 PM
  #66
vjsimone's Avatar
vjsimone
The OP was just curious to the definitions to the acronyms on his vacuum hose routing map. He has a Holley now, Ford went to Holley as well and gave this 7200 up.... Yeah, it got my curiosity up as well.
That is a fresh air line going into the Choke Diaphragm, no manifold vacuum, seems there is a built in electric heater. The 7200 manual explains it a bit.
Old May 28, 2017 | 10:33 PM
  #67
vjsimone's Avatar
vjsimone
Ok, so I just pulled out my Haynes, 80' thru 88' manual. Low and behold....
Page 150, shows the fresh air port AND a "Choke Control Diaphragm" port on the housing.
Bingo, you guys are right. I must have looked at 50 pictures today and no joy on 2 ports, until just now. So I'm on Board that CM is "Choke Control Diaphragm".
Old May 28, 2017 | 11:17 PM
  #68
vjsimone's Avatar
vjsimone
Originally Posted by zonker
From the Does anyone know what the V, C, CM, and BV stand for?
V – Vent - Fresh Air
C – Choke - Fresh Air
CM - Choke Control Diaphragm
BV - (SB-CBV) Solenoid Assembly- Carburetor Float Bowl Vent
VOTM – Vacuum Operated Throttle Modulator
CPRV - Canister Purge Regulator Valve
TVV - Thermal Vent Valve
Old May 29, 2017 | 02:13 AM
  #69
KULTULZ's Avatar
KULTULZ
Thumbs up
BINGO 2!
You nailed it.
My mistake in labeling V for Venturi Valve.
The tee in the fresh air supply tube (shown on this particular application schematic) must be to supply filtered outside air to the VOTM and EGR controlling solenoids.
Old May 29, 2017 | 07:56 AM
  #70
vjsimone's Avatar
vjsimone
BINGO 2!
I was on board with the Venturi idea as well, and there is a Venturi Valve in that rare beast, and I was just as driven as you to prove the CM symbol. As long as I am learning something, time is well spent.
I'd say the OP, may still need some advise as he sorts out his vacuum lines to his Holley, maybe more to follow..
Well, one of the great things about this site and guys like you, Gary & Dave, and of course, many others, is the collaborative effort. No way this and these results would have been achieved alone without the checks and balances.
Old May 29, 2017 | 08:06 AM
  #71
Gary Lewis's Avatar
Gary Lewis
BTW - What model Holly do you have ?
Thanks, guys. I'll capture these results on my web site later today. But, some of the above is specific to the 7200VV and I'd like to capture it that way. So, which ones?
And, btw, my daughter's name is Holly and she is not named for the Holley carbs.
Old May 29, 2017 | 08:22 AM
  #72
KULTULZ's Avatar
KULTULZ
Post
Actually, all apply to that period (mechanical operated) and the current period (computer operated). Most of the same circuits were used with the 2150 and 4300.
Where he is having trouble with the HOLLEY (whether STD or Emissions Model) might be answered with schematics from the 4180 HOLLEY install of the period.
I bet she is a button...
Old May 29, 2017 | 09:15 AM
  #73
vjsimone's Avatar
vjsimone
Sorry, I could never afford a Holley, much less spell it...
FYI - OP has a; Holley 2300 (1-684, LIST 80179) service replacement carb.
Will look to see if anything is specific.
A quick look shows these acronyms on the 2150, HollEy 1946, Carter YFA & the CFI..... (not that they have the same meaning)
Old May 29, 2017 | 12:28 PM
  #74
Gary Lewis's Avatar
Gary Lewis
As I think about it, whether or not it is VV-specific doesn't matter. So, I've added it all here: Vacuum Diagrams - ???Gary's Garagemahal. Please check it out and let me know if it isn't correct.
Old May 29, 2017 | 01:42 PM
  #75
Franklin2's Avatar
Franklin2
That picture is exactly what I was talking about. And I think I am right in saying Ford never used a fully electric only choke. They called it a "electric assist". Just like the diagram above, they used the electric element AND the hot air from the heat stove also. It has been explained to me that the electric element only heated above 60 degrees F to help the choke spring pull off faster during warmer weather.
