Why does my truck run better with the MAP sensor unplugged
A stuck open EGR valve can cause the simptoms described, and "faulty" MAP sensor can be a - consequence - of that. In reality, it is not, but, MAP, having been read off by the computer, with the EGR valve being all clogged up, and stuck open, the system can get in a "data conflict" and thus, as a precaution, PCM just cuts the power to turbo, as if, "not to cause damage to the system, due to a conflicting data". This MAY be the reason for the way his engine behaves. Either way, this is something he must address, (if hasn't done so yet), and see if it solves the problem.
Try this link:
7.3 EGR Link
There is plenty to mine for info there.
Now, it is my turn to provide a Google search result.
7.3 EGR location
Perhaps you are thinking of the exhaust back pressure sensor (EBPS) or the exhaust back pressure valve (EBPV) or the IPR, ICP, etc?
We DO NOT have an EGR valve on our trucks.
We have a 2004, V8, Diesel Powerstroke.
Ford Stealership diagnostics clearly show an EGR valve present - center of the engine block, close to the radiator...
Your killing me here Smalls!
The 7.3 was not made in the USA market after 2003. Ironically enough, the pictures you posted and which I quoted look a lot like a 6.0 engine bay. Which does in fact have an EGR.
See the alternator that you referenced, and the hexagon shaped lid that are in both your picture and my picture?
Here it is again...
If that is not enough, notice the tubing in the picture you posted directly behind the alternator, here it is again in my picture.
All of these are pictures of the 2004 6.0 liter Power Stroke V-8 diesel. Not the 99-03 7.3 liter Power Stroke V-8 diesel.
You are wrong about the EGR on the 7.3. Your receipt from a stealership clearly showing a EGR is present. I agree, but your detective work, needs some work. The receipt shows a 2004, which is a 6.0 liter, not a 7.3.
Thank you for posting the VIN though, which when Googled comes up as a 6.0 liter....
https://the-car-directory.com/VIN_1F...933_see_decode
I tried to be nice, but I can only say it nice so many times before I outright say you are wrong about the EGR on the 7.3.
Zoom in? That is not a 7.3 liter, it is a 6.0! This is the 7.3 liter section of the forum. Perhaps you were not aware of what section you were in?
New Castle is a good choice.
Splashing bile? I have been very polite and started leaning toward being very direct in my last post. This is who I am. I am a retired Senior NCO and being direct is a way of life for me.
This is an adult conversation, and I have been wrong many times, just ask my wife. An adult can admit when they are wrong and move on with it and learn from it. Some one saying they are neither wrong nor right in a matter such as this, well that is wrong.
I do realize that I do not have to reply to your posts. But, again I have an obligation as a contributing member of FTE to provide factual and relevant information in the thread. It is a shame that this thread has gone so far off track from a MAP sensor problem, but it is what it is.
My intent is not to prove you wrong, my intent is to set the record and information in this thread straight.
THERE IS NO EGR VALVE ON THE 7.3 LITER DIESEL!
I realize he is new to the FTE, and a welcome addition. Although, if we allow for misinformation to be spread, then the FTE will turn into all of the other forums out there full of BS. This is just like last week when I called the part that connects to the pitman arm a track bar by mistake. AndyM was nice enough to correct my terminology and I went back and edited my posts so future searches and information seekers were not confused by me using the wrong terms.
I will never catch up, but I don't mind being the middle somewhere. It allows for a clearer view most of the time based on my experiences.
I have no idea if he knows anything about the different versions, or if he's some master mechanic. I'm thinking maybe he learned something from a difficult or costly problem and tried to pass it on.
Hopefully he now understands the mistake and will come back and we all shrug it off.
You were much more polite than most forums out there, good job
