2006 random missfire code
Old May 23, 2017 | 09:44 PM
steve(ill)'s Avatar
steve(ill)
Friend has a 2006 with the 4.6 motor. From time to time he gets a random misfire code ( I think its 0316).. He claims it will only do it when the gas tank is less that half full. I don't see any correlation between fuel level and the code. I am going to check fuel trim values, etc, when the code is set, this weekend.... all I can assume is low fuel pressure which sets the code... Anybody seen a problem with the pressure module or fuel pump / discharge hose that is related to low level in the tank ?
Old May 24, 2017 | 09:18 AM
alloro's Avatar
alloro
When the fuel is less than 1/2 a tank the pump is exposed to air. The fuel acts as a heat sink and keeps the pump running cooler. When worn pumps heat up they produce less pressure and result in lean conditions and misfires, especially under a load.
Old May 24, 2017 | 12:52 PM
pdqford's Avatar
pdqford
I *think* the P0316 indicates random misfires within the first 1000 rpm s after start up.
Maybe a leaky check valve within the fuel pump.
You could try cycling the key between off and run a time or two to prime the fuel pump cranking the engine up. See if that keeps the code at bay.
Old May 24, 2017 | 05:54 PM
steve(ill)'s Avatar
steve(ill)
I put a new pump in it 2 years ago due to "fuel problems". Ran OK for quite a while after that.. Now he says it can run for WEEKS with no code and no problems.. let the level fall below half tank and he gets the code.. Fill up and the code goes away.. That's his story. I will try to get more info this weekend .... hate to think its the pump again.
kevinwheatcroft
13
Aug 13, 2016 07:26 AM
randinow
Jan 8, 2010 11:09 PM
Smokey1
Mar 27, 2009 11:24 PM
tatesomero
1983 - 2012 Ranger & B-Series
Mar 15, 2004 07:01 PM
gibsondog
Nov 5, 2003 09:47 AM
