Intermittent Fuel Pump
Old Mar 25, 2009 | 06:12 PM
Smokey1's Avatar
Smokey1
03 PSD, Been having issues where it will lose virtually all power, it will barely idle and if i shut it off it won't start..If i leave it for 5 mins it will start up fine. I've had 2 previous pump failures and fuel contamination issues, today i dropped the tank, drained and cleaned it, flushed the lines, put new fuel filters on it and got it back together, after driving approx 25 miles, it did it again..Is it possible that the fuel pump is failing intermittently? If i can get a code reader, will it throw a Low fuel pressure code? I want to be sure before i order one as they aren't cheap.
Old Mar 25, 2009 | 06:24 PM
69cj's Avatar
69cj
Sounds like your ICP could be failing. Try unplugging it and see if your symptoms change.
Old Mar 25, 2009 | 06:25 PM
Iowan50220's Avatar
Iowan50220
sounds like possibly a FICM issue.....a code reader would help out regardless....at least point you in a direction maybe...Just a thought
Old Mar 25, 2009 | 07:31 PM
Smokey1's Avatar
Smokey1
I've already replaced the ICP with a second gen unit so i don't imagine that's the issue.
Old Mar 25, 2009 | 09:24 PM
toolman05kr's Avatar
toolman05kr
Have the fuel pressure checked, if the pump or fuel pump relay is going bad the pressure will be low or irratic. also cam sensor?, it's uncommon but not unheard of. good luck.
Old Mar 25, 2009 | 10:46 PM
Smokey1's Avatar
Smokey1
Well, i just found one on ebay brand new in box for $49.99.......So i guess for that price it's worth a shot. The dealer wanted $437 when i called this afternoon
Old Mar 26, 2009 | 08:14 AM
69cj's Avatar
69cj
Found one what??
Old Mar 26, 2009 | 06:16 PM
Smokey1's Avatar
Smokey1
I found a fuel pump on ebay for 49.99
Old Mar 27, 2009 | 11:24 PM
Smokey1's Avatar
Smokey1
I should add that i've also noticed the following after monitoring for the last few days
1.It will only give me trouble when under 1/2 tank.
2.Highway/steady driving is fine, usually acts up after coming to a stop, idle
Hotairjunkie
Modular V10 (6.8l)
Aug 15, 2019 01:12 AM
TheWhiteBeast
24
Jul 31, 2011 10:24 AM
randinow
Jan 8, 2010 11:09 PM
frankenstein f-150
Oct 19, 2009 06:32 PM
vaultster
Mar 19, 2007 07:19 PM
