Missing
Old Jun 1, 2017 | 07:30 PM
redfishtd's Avatar
redfishtd
I'm not here to challenge you, it's only my opinion
I have seen the black carbon on the spark plug nut and porcelain and it indicates blowby . The gases are coming out the plug threads . A common complaint is the smell of fuel in the cab . It seems to burn the tips of the plugs , I run champions at this time but next time I will go to sp515's . That's 3 sets of champions with no trouble but now I believe mc has fixed the problem .
The only thing I can deduce is the extremely hot gases running by the tip instead of thru valves is having a torch action on those tips . The carbon built up around that point must be like charcoal ,even glowing on the intake stroke as it surely is pulling oxygen in around those threads . Just my guess .
Old Jun 1, 2017 | 09:46 PM
nddragon01's Avatar
nddragon01
I stand corrected. What you state sounds very much plausible and good reasoning as to what happened with that plug in particular. Thank you for the explanation.
​​​​​​... it might also explain the burnt fuel smell I get in the cabin when using the heat or a/c...?
grounded
1983 - 2012 Ranger & B-Series
52
Apr 8, 2019 07:49 PM
Mental-issues
23
Apr 2, 2017 07:14 PM
southernchaos
23
Mar 9, 2011 10:19 PM
wcurtis
Modular V8 (4.6L, 5.4L)
Jan 5, 2007 11:34 PM
lawnspecialties
29
Dec 23, 2005 11:50 PM
