Plugs
Old Dec 29, 2006 | 08:32 PM
wcurtis's Avatar
wcurtis
Plugs
I just changed the plugs on my 2001 f250 superduty, the plugs where white looking, I'm I not getting enough gas??? How to you fix it???
Old Dec 30, 2006 | 10:17 PM
ReAX's Avatar
ReAX
First thing first, when did you last change o2 sensors and fuel filters? If it's been a while, replace them, they can cause you to run lean. Clean your MAF.
After that, you might have fuel pressure issue, or your tune is set lean.
Old Jan 4, 2007 | 11:32 PM
Bluegrass 7's Avatar
Bluegrass 7
In a fuel injection engine, you can't read the plugs that close like a carbed engine.
The PCM keeps the fuel ratio so tight that the plugs look that way normally.
Only data logging the OX sensors can tell you if the engine is truely lean at any point in the total operation.
Old Jan 5, 2007 | 07:37 AM
redford's Avatar
redford
FTE Leadership Emeritus
A grayish tan to while color indicates the correct heat range spark plug is in use, the fuel and ignition systems are in good shape and overall engine mechanical condition is good.
Old Jan 5, 2007 | 11:34 PM
wcurtis's Avatar
wcurtis
Thanks Guys!
mrsvegan
17
Oct 19, 2013 07:26 PM
jspringator
Modular V10 (6.8l)
Oct 19, 2013 08:50 AM
stevelacey75
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Nov 12, 2004 08:29 PM
shakespearesdad
Oct 27, 2002 08:54 PM
millbobs
Mar 30, 2001 06:26 PM
