15 DRW Wheel Width
Old Jan 5, 2020 | 10:46 AM
  #46
toddb1's Avatar
toddb1
Thanks for following up on this, I'm shopping for replacements for mine. How would you rate the noise on these on the highway?
Old Jan 5, 2020 | 12:57 PM
  #47
Superduty450's Avatar
Superduty450
They are very quiet compared to BFG all terrains, not much noisier than the stocks.
Old Jan 5, 2020 | 01:15 PM
  #48
Gmj0831's Avatar
Gmj0831
Thanks for your help. Does anything hit or rub when turning? When loaded do you have any concern of the duals touching?
thanks
Old Jan 5, 2020 | 02:13 PM
  #49
Superduty450
Nothing hits or rubs when turning and there is plenty of room between the duals, I run 75psi when loaded which is 4300lbs of pin weight plus I have ab 75 gal fuel tank in bed and there is no tire bulge. I will buy them again when the time comes, the only downfall might be a slight loss in fuel mileage but that is expected with a more aggressive tire.
Old Mar 22, 2020 | 08:10 PM
  #50
Gmj0831's Avatar
Gmj0831
Hey Superduty,
What air pressure are you running in the front tires? I just had them installed and overall really like them. Only thing that I notice is the front seems to wonder a little. I am thinking I may should let some air out of the front. I am currently running 75 PSI.
Old Mar 22, 2020 | 08:51 PM
  #51
Just Strokin's Avatar
Just Strokin
The DRW tire psi for my 2015 is 65 in all 6 tires.
Old Mar 23, 2020 | 08:51 AM
  #52
Superduty450
I run 75psi in the fronts all the time, rears when hauling 4K plus is 75psi. Running empty rears are at 55psi. Those Toyos need about 500 plus miles to break in.
Old Mar 23, 2020 | 10:54 AM
  #53
scraprat's Avatar
scraprat
Top Answer: 5
Same here, 65 all around in my "16".
Old Mar 23, 2020 | 11:01 AM
  #54
Superduty450
These are not the same size nor ply ratings of whats on a door sticker. I adjust pressures according to tire wear patterns
94xltsc
Jan 5, 2020 10:43 AM
BuiltFordTough!
Jun 29, 2013 07:56 AM
uliman
Aug 14, 2007 04:36 PM
Burr
Mar 11, 2004 06:33 AM
