Speedometer not working
Old May 21, 2017 | 12:37 PM
floydman1981's Avatar
floydman1981
I have a 2001 F350 that I recently purchased the speedometer was not working when purchased and I cant see to figure out why. I have replaced the speed sensor in the rearend. I replaced clockspring. All other gauges are in good working order. Cruise control works. Any ideas?
Old May 22, 2017 | 09:12 PM
floydman1981
Bump. Help anyone got idea of what the problem might be.
Old May 22, 2017 | 11:28 PM
retiredsparky's Avatar
retiredsparky
Check the grounds near the parking brake for rust/bad connection. If you have ABS, check your wiring to the ABS unit, including local grounds on the driver's fender(under the hood). Are all your fuses in good shape?
did you visually inspect the VSS wiring as it leaves the sensor area and goes up into the body for mice snacking or road debris damage? When you plugged in the VSS did you look carefully at the wire harness connector at the VSS for corrosion (blue green coloring)? You need a scanner that can monitor the VSS for signals.
Larry
05 f250 6 inch lift
Aug 3, 2017 04:44 PM
scubajt
Jul 9, 2011 10:05 AM
Encho
1978 - 1996 Big Bronco
Dec 15, 2009 08:57 PM
lee231
Aug 16, 2009 09:37 PM
550superdutytwinn
Feb 20, 2008 07:47 PM
