"The Shakes"
Old May 21, 2017 | 10:09 AM
thatdarncat's Avatar
thatdarncat
"The Shakes"
Hi Folks,
On my 1994 f-350 dually idi turbo it will start smoothly and run and drive smooth but when I cut the engine off the front end gives off a good shake as the engine stops...any ideas on this?
I have not crawled underneath it to look at the motor mounts closely but could this be a motor mount problem?
Old May 21, 2017 | 03:14 PM
PlumCrazy7's Avatar
PlumCrazy7
Natural to diesel engine as fuel is cut and imbalances are created as cylinders stop firing.
Old May 22, 2017 | 01:30 PM
hairyboxnoogle's Avatar
hairyboxnoogle
I dont notice it, but ive had several passengers comment that mine feels like it "locked up" when i shut it off just because it stop so suddenly. Probably just the momentum of the rotating assembly coming to a stop when it hits the cylinder on compression. Since there is alot of compression, it STOPs lol. My theory anyway. Could post a vid, but im betting its normal. Food for thought, most gas engines build around 150-170 psi just at cranking speed, an IDI is building between 400-500psi.
Old May 22, 2017 | 05:46 PM
thatdarncat
Thanks folks, that is good news. As soon as some of this rain ends I will crawl under there and take a close look at the motor mounts just to be on the safe side.
I went from a 2000 7.3 powerstroke to the 94 IDI turbo, mostly because it seems easier to work on and is cheaper to buy parts for. However, when I use to cut the Powerstroke off it didnt seem to shake as much, so I was kind of concerned.
Old May 22, 2017 | 09:52 PM
Macrobb's Avatar
Macrobb
One thing of note is that if it's a manual, you probably have a DMF - the flywheel is actually in two(very heavy) pieces that rotate a little with springs to provide the thrust.
The free-play between the pieces means that when the engine stops suddenly, the back half of the flywheel bounces back and forth a bit off the springs, producing a definite clunk and shake.
SMF-converted trucks tend to do that less, but have their own issues - mainly rattling in neutral due to the diesel pulses(especially if the motor isn't running perfectly smoothly), and low-RPM gear noise.
craigula
Mar 16, 2009 06:47 PM
BIG BLACK TURBO
42
Feb 23, 2009 08:11 PM
griff88_81
Feb 15, 2009 04:49 PM
junkyardkid2002
Jan 7, 2009 05:29 PM
78bigunns
Nov 13, 2008 02:35 PM
