Ecu? 1989 Superduty 7.3 manual transmission
Okay guys I am pulling my hair out I picked up this 1989 Ford Superduty with a manual transmission currently it has an ECU located in the firewall come to find out at one time this truck was a automatic so I guess my question is how do I bypass the ECU in order for everything that ran through it to work properly?
What all does run through it?
thanks in advance anything would help
Received 3,102 Likes
on
so does that mean the only thing I have to bypass is the wires for the RPM gauge?
on
The tach sensor on these is apparently pretty common to fail from what I've read. They're not cheap either. Someone found out you can use a cheaper sensor and modify it to fit. I can't remember what it's called. It was a Honeywell sensor of some kind.
Also, I saw your other post. You won't be able to pull codes in one of these. Everything is mechanical and there's no computer to tell you what's wrong (or to cause issues either).
Luckily the guys around here are pretty smart and helpful. Also, these trucks are pretty simple too which definitely helps!
on
i will admit i do not know very much about the electronic auto transmissions, all my trucks had C-6 autos except for the 88 which had the 5 speed before the transfer case let loose in 05 at 375,000 miles and took the trans out with it.
that was when i put a C6 in the 88.
91dually
08-18-2012 01:49 AM
Mitch1407
03-01-2011 09:56 AM
gixxxerrider600
02-16-2008 12:32 AM
