2011 Ford F350, 69K miles Squeak from wheels front
the bolts on the caliper bracket are torqued on with blue lock tight so a large breaker bar with persuasion extension was needed to get them to give.
Ha Ha, I don't have access to a Big Friendly Giant so maybe BFH?
Thanks, sounds easy enough. The Ford engineers were thinking of serviceability when they built the Super Duties.
Once you get the Wheel off, then the caliper and then caliper bracket they come off. Now the fronts came right off. The rears needed a little persuasion to come off. Had to loosen the rust inside ... But a few taps with a hammer it finally loosened enough to pop off.
Received 6,710 Likes
on
What type of pads comes OEM on the Superduty? My Titan came with ceramic pads from the factory and the brakes were horrible. I replaced the OEM rotors/pads with Bosch rotors and Bosch non-ceramic pads and the braking was much better. I tried ceramic on my wife's minivan and the braking performance was significantly degraded.
Consequently, I would be very reluctant to try ceramic pads again unless Ford put ceramic pads on at the factory.
Harpo2013
6.7L Power Stroke Diesel
22
06-16-2014 08:55 PM
