Guidance
Old May 19, 2017 | 09:02 PM
Justfishin's Avatar
Justfishin
Guidance
I have a 1997 F250 7.3 SD with 268000 miles on it. I am experiencing some lifting in the front and floating when I have my trailer attached. It has not done this before. Any help appreciated.
Also its a short bed and I would like to improve the ride. I guess decrease the roughness when driving. What can I do?
Thanks in advance.
Old May 19, 2017 | 09:10 PM
z31freakify's Avatar
z31freakify
Welcome to FTE
Is it 4X4 or 2wd? I'm assuming lifting mean it sways correct? Check all your steering components for loose or worn out tie rods
Old May 19, 2017 | 09:31 PM
Justfishin's Avatar
Justfishin
6 spd, 4X4 warn hubs, Tie rods seem to be ok. Had an issue with the center link and its been replaced. Brother thinks its leaf springs in rear or shocks.
Old May 19, 2017 | 09:41 PM
z31freakify
Do you have a rear sway bar? If so check the bushings and the end links.
Old May 19, 2017 | 10:09 PM
Justfishin's Avatar
Justfishin
Will check.
What about the axle swap I hear and been reading about. Will this do anything for the ride?
Old May 20, 2017 | 07:24 AM
Shawn MacAnanny's Avatar
Shawn MacAnanny
By floating so you mean in the steering? These steering boxes aren't great and wear out causing that. Less front end weight can amplify the feeling. Also a loose pitman arm nut can feel the same.
Old May 20, 2017 | 06:14 PM
Justfishin's Avatar
Justfishin
Yes the steering.Will check that out also. Thanks
Old May 21, 2017 | 09:18 PM
Justfishin's Avatar
Justfishin
Sway Bar
No I dont have a rear sway bar
Old May 23, 2017 | 08:41 PM
knottyrope's Avatar
knottyrope
thought my steering was getting a little loose. Pitman nut was a bit loose. Got a half turn in it and look forward to my morning commute. Reps sent
Old May 26, 2017 | 06:20 AM
tjc transport's Avatar
tjc transport
i ain't rite
there may very well be nothing wrong with the truck, and the problem may actually be as simple as weight distribution in the trailer has changed and too much weight is in the front of the trailer lifting the front end of the truck
TheSchultMeistr
Dec 25, 2015 05:52 PM
03X
Nov 26, 2015 09:14 AM
mcgovn
Oct 31, 2012 02:40 PM
bumparker
Feb 18, 2012 03:01 PM
JQ
Oct 19, 2002 06:04 PM
