Clutch bleeding tool
Old May 19, 2017 | 06:38 PM
wtroger's Avatar
wtroger
Here is a picture of a tool I concocted to bleed the clutch hydraulics on these Rangers you all may have already come up with something like this but this works slicker then anything I have found. Just insert the point in the hole at the bottom of the reservoir there is a small o-ring on it to seal. Then pull the plunger back on the syringe if there is any air in there you will get a string of bubbles. Let the bubbles dissipate then push the fluid back in. I always start with some fluid already in the syringe. Did this today had a bad master clutch cylinder. Swapped it out did the pump it upside down routine before putting back in the bracket. Did the syringe thing got a big string of bubbles. Pushed fluid back in did this a couple of times until I no longer got bubbles. Fired the truck up clutch worked perfectly.
Old May 21, 2017 | 01:53 AM
Lanciadave's Avatar
Lanciadave
That is genius! Thanks for the info. This could save me a lot of work next time
ianmcg1988
Dec 26, 2012 11:26 PM
Pablo-UA
Aerostar
Feb 27, 2009 04:40 AM
TheRon
Bronco II
Oct 13, 2008 10:16 PM
123svt
18
Mar 25, 2006 10:57 PM
corndoggydog
Mar 28, 2004 01:10 PM
