Leaky C6 Trans
Old May 24, 2017 | 01:29 PM
  #31
DeepRoots's Avatar
DeepRoots
The ***** can only fall out of valve body if you take the valve body apart.
To change the filter you don't need to take the valve body apart :P
I'd change the filter on the table just cuz..... I'm sure you've noticed by now, the valve body will leak way more fluid than you'd think possible, so be wary about flipping it over and more will gush out randomly.
The valve body to transmission (3/8 head) bolts are 100inch lbs. The rest are listed below in a picture I took.
If you don't have an inch lb torque wrench just get them tight with a nut driver, or a speed wrench. Under tightening isn't a massive issue, just don't get crazy over tightening them.
To message me, either click on my username and it should be an option. I normally don't come here unless there is a thread like this.
Dp
Old Jul 12, 2017 | 04:22 PM
  #32
udamanbaby's Avatar
udamanbaby
Trailering
Just to finish off the thread, turns out for me it was the outer O-ring on the kick down that failed and caused the leak. I went to a local transmission shop and the guy at the counter gave me a new one, no charge. He gave me the new "flat" style seal that isn't actually an o-ring, but looks more like a tiny little tire. I popped it in no problem and the leak stopped. Thanks for all the info guys. I appreciate it!
Old Apr 9, 2018 | 10:53 AM
  #33
EagleChief's Avatar
EagleChief
Reviving an old thread....
I'm having the same issue and reading this thread has me wondering - if it's the O-ring on the kickdown linkage, which (to me) would be the last line of defense, so to speak, wouldn't that mean that there is a leak further in? Meaning the seal at the shifter linkage? For my sake, I'm hoping my leak is the outer O-ring. But if it is, I'm afraid that means the inner seal is also bad to allow fluid to get to the outer O-ring. Unless, this is by design.
From what I read, it doesn't sound all that bad to change out either, but, I'd only like to do what's necessary to stop the leak. So, far I've done all the work on my truck to get it running again, but, I've never worked on a transmission before, so the thought of opening mine up, scares the bee-g-sus out of me.
Old Jun 25, 2018 | 10:01 AM
  #34
EagleChief's Avatar
EagleChief
Anyone know what size that little o-ring is at the kickdown? I replaced the seal and the o-ring, but I don't think the o-ring I used was exactly the right size. I still have a leak at that point. So, now I need to find the correct o-ring to put in there. Any help?
Old Jun 26, 2018 | 09:00 PM
  #35
jackietreehorn's Avatar
jackietreehorn
Originally Posted by udamanbaby
Hey everyone,
I have a '75 F250, FE390 w/ a C6. There is transmission fluid slowly leaking from the linkage on the transmission where the shifter levers attach. Is there some kind of seal that might have failed? It's the area highlighted with light in the photo.
Also, there seems to be some sort of plug next to the linkage, I tried to tighten that in case it was loose and the source of the fluid, but didn't make a difference. What is that plug for?
IIRC, that “plug” is actually the intermediate band adjustment.
you may want to loosen it and torque it to proper setting, if you messed with it.
1browski
Jun 10, 2019 05:37 PM
f100help
Nov 15, 2010 07:03 PM
3xrace
Sep 4, 2007 10:01 AM
Spinach Chin
Oct 1, 2003 08:12 AM
ejb4x4429
Feb 7, 2003 09:59 PM
